ZFS mirror capacity
bobbus
I'm going for a new small NAS setup with 2 mirrored data disks of 1,5TB.
Looking at FreeNAS in a VM guest (to test with) I found that the capacity of a ZFS mirror is only half of what you would expect, meaning only 750GB instead of 1,5TB.
When you create a zpool from CLI in FreeNAS, with:
# zpool create -m /mnt/data data mirror ada1 ada2
then you do get 1,5TB of usable capacity on the mirror.
Where does FreeNAS use the extra (50%) capacity for? Snapshots? How do you bypass this behavior? Creating ZFS pools from CLI does not reflect in the GUI, so they're not usable...
Thanks for your help!
Bob
the available space will be the size of your smallest drive in the mirror. 2, 1.5 TB drives will make a 1.5 TB mirror. a mirror with a 1 T drive and a 1.5 TB drive will make a 1 T mirror.
FreeNAS reserves 2 GB on each drive for a pagefile... did you create your VM with 4 GB disks perhaps?
bobbus
Thanks for your reply!
That makes sense, I tested with 4GB virtual disks indeed.
Thanks again!
