John Gorst
 - Dec 18, 2014
FreeNas 9.3-stable on N40L 8gb
I have two 500gb (approx) disks running as a ZFS mirror.
I want to change them to two 3gb disks.
I have capacity to have all four to be installed at the same time.
If I use the GUI I need to 'replace' one of the 500gb disks with a 3tb disk.... this means I am running on only one disk whilst it is replicating which will be slower and more 'risky'
Can I just use the CLI to attach the 3gb disks to the Mirror and later remove the old ones?
(where ada2 and ada3 are the new 3tb disks)
However I note that the existing disks seem to have partitions on them...swap file and random space?. Do I need to replicate this swap file partition and how?
I have found similar questions in the past but can't find a succinct answer for a recent version. A previous answer asked for a 8gb swap file in a gpart command so I was not entirely convinced to its reliability.
Thanks for any help
zpool attach datastore ada2 ada3 (give it time to resilver) zpool detach datastore ada0 ada1
[root@garage] ~# gpart show ada0
=>       34  976773101  ada0  GPT  (465G)
         34       2014        - free -  (1M)
       2048  976754688     1  !6a898cc3-1dd2-11b2-99a6-080020736631  (465G)
  976756736      16384     9  !6a945a3b-1dd2-11b2-99a6-080020736631  (8.0M)
  976773120         15        - free -  (7.5k)Thanks for any help
