ZFS Fragmentation with Torrents
SeaWolfX
I've read a few places that downloading torrents onto a ZFS storage causes a lot of fragmentation (also a lot of fragmented free space even if the file is moved) and I have a few questions in that regard:
1) Is there any recommended ZFS tuning that can limit this (I've read recommendations for recordsize of 16K and 1M for torrent datasets so it is a bit confusing).
2) Is this an issue with SSD? And if using SSDs for torrents will it cause a lot of wear on the drives?
3) Can zpools be defragemented somehow?
3) Is the best option to just use a separate harddrive without ZFS for torrents?
Depends on the size of the "parts" of the torrents. Try to match that (or at least use even multiples).
Destroy pool, put contents back.
Maybe, but that isn't really an option in TrueNAS.
What you might want to do is:
Turn off the pre-allocation of torrent files as a pre-emptive write of the whole file and subsequent re-writes of all parts as they arrive would mean a lot of churn for a Copy on Write filesystem like ZFS. This is in the Torrent client, not TrueNAS itself.
Turn off/don't set/delete all snapshots for that dataset/pool.
HDDs usually have a higher TBW for a given size, so consider that, but it's not really any harder or easier on SSDs in terms of data written.
jgreco
Resident Grinch
Yes, there's a lot you can do. The torrent problem is a variation on the small block storage problem, which is discussed extensively at
https://www.truenas.com/community/threads/the-path-to-success-for-block-storage.81165/
You mitigate fragmentation for reads with heaps of ARC and L2ARC, meaning that you simply try really hard to avoid hitting the pool for reads. You mitigate fragmentation for writes by maintaining heaps of free space, as in, maybe only use 25% of your space.
This assumes you want it to be fast. If you don't, just don't worry about it and it'll be fine.
Combine this with the message from @sretalla for a complete-ish answer.
