ZFS - Drives go offline/removed - Cant seem to get SMART reports
BigOBX
Il willing to post more detailed info if needed but im running:
FreeNAS-9.3-STABLE-201501090144
i have three ZFS pools, two are working fine using the on board controllers but my third larger pool is not working well. When i first get the system up and running about 3 weeks ago, the pool was working fine for a few days i actually moved a bunch of data to the array, i then moved the data away from that array. A few days later i noticed that there were some update's available so i did the updates via the gui and maybe 3-4 days after that i started having issues with the pool.
Here is the current status of the array:
[BigO@FREENAS] ~% zpool status LSI-11TB
pool: LSI-11TB
state: UNAVAIL
status: One or more devices could not be opened. There are insufficient
replicas for the pool to continue functioning.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-3C
scan: scrub repaired 4K in 0h0m with 0 errors on Mon Jan 12 11:38:36 2015
NAME STATE READ WRITE CKSUM
LSI-11TB UNAVAIL 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/2430592d-999d-11e4-9d68-001b212dea45 ONLINE 0 0 0
gptid/24cbca20-999d-11e4-9d68-001b212dea45 ONLINE 0 0 0
gptid/256fcc61-999d-11e4-9d68-001b212dea45 ONLINE 0 0 0
gptid/260e424d-999d-11e4-9d68-001b212dea45 ONLINE 0 0 0
raidz1-1 UNAVAIL 0 0 0
1084237407502822741 REMOVED 0 0 0 was /dev/gptid/26bf5793-999d-11e4-9d68-001b212dea45
gptid/276a88f2-999d-11e4-9d68-001b212dea45 ONLINE 0 0 0
14279668410874385647 UNAVAIL 0 0 0 was /dev/gptid/280fa588-999d-11e4-9d68-001b212dea45
8516515671396866123 UNAVAIL 0 0 0 was /dev/gptid/28afd0f9-999d-11e4-9d68-001b212dea45
errors: No known data errors
If i try to "online" the drives the status doesnt change:
[BigO@FREENAS] ~% sudo zpool online LSI-11TB 1084237407502822741
warning: device '1084237407502822741' onlined, but remains in faulted state
use 'zpool replace' to replace devices that are no longer present
[BigO@FREENAS] ~% sudo zpool online LSI-11TB 14279668410874385647
warning: device '14279668410874385647' onlined, but remains in faulted state
[BigO@FREENAS] ~% sudo zpool online LSI-11TB 8516515671396866123
warning: device '8516515671396866123' onlined, but remains in faulted state
I tried to set up a smart report to run every hour on these drives but im not getting any emails about it but i am getting other emails from the NAS so im at a loss there as well.
Please help me out, the array is new and there is no data on it so im not worried about that but would like to get the array working so that i can begin using it soon as my Synology is running low on space and ill need to get this going soon.
Hardware specs would help--motherboard, CPU, RAM (type and quantity), disk controller, firmware type and version on the disk controller, disks. RAIDZ1 isn't recommended; your data would be safer with an 8-disk RAIDZ2 configuration, but I don't think that's your problem right now.
What's the output of camcontrol devlist?
SMART only sends emails if there are errors, so you shouldn't expect SMART emails on a routine basis.
BigOBX
MotherBoard - asus a8n-sli
cpu - opty 165
mem - 4gb kingston value ram
controller - intel sa8ci flashed with LSI IT firmware
disks - WD20green ears
[BigO@FREENAS] ~% sudo camcontrol devlist
<WDC WD1001FALS-00J7B0 05.00K05> at scbus2 target 0 lun 0 (pass0,ada0)
<WDC WD1001FALS-00J7B0 05.00K05> at scbus3 target 0 lun 0 (pass1,ada1)
<WDC WD1001FALS-00J7B0 05.00K05> at scbus4 target 0 lun 0 (pass2,ada2)
<WDC WD1001FALS-00J7B0 05.00K05> at scbus5 target 0 lun 0 (pass3,ada3)
<WDC WD10EADS-00M2B0 01.00A01> at scbus6 target 0 lun 0 (pass4,ada4)
<WDC WD10EADS-00M2B0 01.00A01> at scbus7 target 0 lun 0 (pass5,ada5)
<WDC WD10EADS-00M2B0 01.00A01> at scbus8 target 0 lun 0 (pass6,ada6)
<WDC WD10EADS-19M2B0 01.00A01> at scbus9 target 0 lun 0 (pass7,ada7)
<ATA WDC WD20EARS-22M AB51> at scbus10 target 0 lun 0 (pass8,da0)
<ATA WDC WD20EARS-22M AB51> at scbus10 target 1 lun 0 (pass9,da1)
<ATA WDC WD20EARS-22M AB51> at scbus10 target 2 lun 0 (pass10,da2)
<ATA WDC WD20EARS-22M AB51> at scbus10 target 3 lun 0 (pass11,da3)
<ATA WDC WD20EARS-22M AB51> at scbus10 target 4 lun 0 (pass14,da4)
<ATA WDC WD20EARS-22M AB51> at scbus10 target 5 lun 0 (da5,pass15)
<ATA WDC WD20EARS-22M AB51> at scbus10 target 6 lun 0 (pass13,da6)
<ATA WDC WD20EARS-00M AB50> at scbus10 target 7 lun 0 (pass12,da7)
< 8.07> at scbus12 target 0 lun 0 (pass16,da8)
Well, your hardware is suboptimal in at least a few ways: (1) AMD processors aren't generally recommended with FreeBSD, (2) desktop-grade motherboard, (3) non-ECC RAM, and (4) only half the minimum amount of RAM. I don't really expect that any of these is what's causing your problem, but none of them is good, and we've seen lots of pools lost when users don't have enough RAM. What version of the IT firmware are you using?
Tell us a bit more about your disk arrangement. Your zpool status indicates 8 disks, in two four-disk RAIDZ1 vdevs. Your camcontrol devlist lists 16 disks. Which 8 are in use in your pool, and what are you doing with the other 8? How are all of them connected?
What's the output (in code tags) of "smartctl -a /dev/ada0"? What about "smartctl -a /dev/da0"?
BigOBX
Yeah the hardware isnt the best but ran the old version of freenas before the fork pretty well. I know this version is not the same but dont really have the funds for a whole new build so i had to work with what i had laying around.
i dont recall the firmware version right now but cant get that info a bit later as im going to be stepping out soon and need to bounce the box to get that info. It could potentially be out of date as i flashed it about 2 years ago and its been that way since.
The wd20eads disks are the ones that are part of the array in question, the other 8 disks are for my other arrays 4*4 and are working correctly.
Model Family:     Western Digital Caviar Black
Device Model:     WDC WD1001FALS-00J7B0
Serial Number:    WD-WMATV0725302
LU WWN Device Id: 5 0014ee 0abbf14cd
Firmware Version: 05.00K05
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.5, 3.0 Gb/s
Local Time is:    Mon Jan 12 12:51:19 2015 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84)Offline data collection activity
was suspended by an interrupting command from host.
Self-test execution status:      (   0)The previous self-test routine completed
been run.
data collection: (19800) seconds.
capabilities:  (0x7b) SMART execute Offline immediate.
command.
Self-test supported.
SMART capabilities:            (0x0003)Saves SMART data before entering
power-saving mode.
Error logging capability:        (0x01)Error logging supported.
Short self-test routine
recommended polling time:  (   2) minutes.
Extended self-test routine
recommended polling time:  ( 228) minutes.
Conveyance self-test routine
recommended polling time:  (   5) minutes.
SCT capabilities:        (0x303f)SCT Status supported.
SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   230   217   021    Pre-fail  Always       -       8483
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       545
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   057   057   000    Old_age   Always       -       31637
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       543
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       540
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       545
194 Temperature_Celsius     0x0022   118   079   000    Old_age   Always       -       32
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
Warning: ATA error count 80 inconsistent with error log pointer 1
ATA Error Count: 80 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 80 occurred at disk power-on lifetime: 31091 hours (1295 days + 11 hours)
  ER ST SC SN CL CH DH
  40 51 00 0b 02 00 e0  Error: UNC at LBA = 0x0000020b = 523
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  c8 00 10 00 02 00 00 02   1d+01:14:59.415  READ DMA
  c8 00 10 00 02 00 00 02   1d+01:14:57.076  READ DMA
  c8 00 10 00 02 00 00 02   1d+01:14:54.736  READ DMA
  c8 00 10 00 02 00 00 02   1d+01:14:52.243  READ DMA
  c8 00 10 00 02 00 00 02   1d+01:14:50.071  READ DMA
Error 79 occurred at disk power-on lifetime: 31091 hours (1295 days + 11 hours)
  c8 00 10 00 00 00 00 02   1d+01:14:50.070  READ DMA
Error 78 occurred at disk power-on lifetime: 31091 hours (1295 days + 11 hours)
  c8 00 10 10 00 00 00 02   1d+01:14:50.070  READ DMA
Error 77 occurred at disk power-on lifetime: 31091 hours (1295 days + 11 hours)
  c8 00 10 80 00 00 00 02   1d+01:14:50.070  READ DMA
Error 76 occurred at disk power-on lifetime: 31091 hours (1295 days + 11 hours)
  c8 00 10 00 02 00 00 02   1d+01:14:47.898  READ DMA
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Model Family:     Western Digital Caviar Green (AF)
Device Model:     WDC WD20EARS-22MVWB0
Serial Number:    WD-WCAZA3952563
LU WWN Device Id: 5 0014ee 25ad36a48
Firmware Version: 51.0AB51
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Mon Jan 12 12:53:55 2015 EST
Offline data collection status:  (0x85)Offline data collection activity
was aborted by an interrupting command from host.
Self-test execution status:      ( 245)Self-test routine in progress...
50% of test remaining.
data collection: (35460) seconds.
command.
power-saving mode.
recommended polling time:  ( 342) minutes.
SCT capabilities:        (0x3035)SCT Status supported.
  3 Spin_Up_Time            0x0027   253   253   021    Pre-fail  Always       -       1233
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       152
  9 Power_On_Hours          0x0032   079   079   000    Old_age   Always       -       15973
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       150
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       149
193 Load_Cycle_Count        0x0032   133   133   000    Old_age   Always       -       201230
194 Temperature_Celsius     0x0022   120   113   000    Old_age   Always       -       30
No Errors Logged
# 1  Extended offline    Completed without error       00%     15970         -
# 2  Extended offline    Completed without error       00%     15964         -
# 3  Extended offline    Completed without error       00%     15958         -
# 4  Extended offline    Completed without error       00%     15952         -
# 5  Extended offline    Interrupted (host reset)      20%     15945         -
# 6  Extended offline    Completed without error       00%     15941         -
# 7  Extended offline    Interrupted (host reset)      90%     15934         -
# 8  Extended offline    Completed without error       00%     15930         -
# 9  Extended offline    Completed without error       00%     15906         -
#10  Extended offline    Completed without error       00%     15882         -
#11  Extended offline    Completed without error       00%     15858         -
#12  Extended offline    Completed without error       00%     15835         -
#13  Extended offline    Completed without error       00%     15811         -
#14  Extended offline    Completed without error       00%     15787         -
#15  Extended offline    Completed without error       00%     15763         -
#16  Extended offline    Interrupted (host reset)      60%     15735         -
#17  Extended offline    Completed without error       00%     15715         -
#18  Extended offline    Completed without error       00%     15691         -
SweetAndLow
Sweet'NASty
been run.
command.
power-saving mode.
command.
power-saving mode.
No Errors Logged
lol you don't seem to get it. Your hardware doesn't even come close to meeting the minimum specifications. Because of this the people who could possibly help you probably will not. Since this appears to be something you are testing out take this experience as a successful test. You now know that you should have read the hardware stickies and followed the guidelines.
The SMART test for da0 looks fine, except that your load cycle count is very high--look into WDIDLE3.exe to fix your drive so this doesn't increase so quickly. The LSI firmware should be at P16, which is a few versions behind the current. You're probably OK on this; 9.3 gives you a warning in the web GUI if the version doesn't match.
You've set up SMART to run tests way more often than necessary--a short test daily, and long test every week or two (or even every month) is plenty. Again, I don't think this is what's causing your problem, but it isn't doing any good, either.
I don't have any other input into what's causing your problem at the moment, but 9.3 requires 8 GB RAM, minimum. You have half that amount. You shouldn't be surprised if things aren't working as expected.
+1
BigOBX
I have to admit that i didn't read the Min specs needed like i normally would but didn't think i was that far off due to it being NAS software that is normally light on the min specs but like i said, im currently low on funds and building out a new machine is not something i can swing right now.
Once i get back to work, I will look into getting something to spec built out but for now, i could use any help i can get with the current hardware i have in place so any suggestions or help would be greatly appreciated.
Honestly, at this point, it could easily be a corrupted pool due to non-ECC RAM, insufficient RAM or some wacky interaction between the HBA and the motherboard.
Glorious1
I just had the same problem where two drives disappeared from one RAIDZ1 pool at the same time. I got about 300 emails about failed replication until I got home (does it have to keep trying every minute and send emails every time?). Disk status said they had been removed. I shut it down, pulled and reinserted the drives in that pool, and all was fine when it restarted.
Since I've also been getting occasional (every few days) system crashes and watchdog resets, I vaguely suspect it may be some problem with the HBA (the disappeared drives were on that LSI card) as Ericloewe suggested. But I have no idea how to diagnose it.
Correction - the drives that bugged out were on the motherboard SATA ports.
BigOBX
So i went ahead and read cybers powerpoint (pdf) version and i didn't realize how far from spec i really am. At this point I think its prob best i move back to the nas4free fork that this hardware was running at one point since it ran well under that OS and is closer to the supported spec.
Hopefull when i get back to working ill be able to get the needed hardware for a real freenas rig. The old version was good but this one really seems to be awesome so I will likely come back to it when i can build the proper machine for it.
Other than nas4free, is there any other options for my type of hardware?
