ZFS-8000-8A and then...
DrBobba
First a little background info.
I very much like the idea of ZFS and how it handles. Got a HP microserver with 8GB of ECC ram. With 3 disks of 1.5 TB and one of 2 TB making one Z1 pool of 4.5 TB.
After my most recent scrub I got a ZFS-8000-8A message. Saying it has 10 write errors in my first and largest dataset.
Found out that 5 files are affected. The files that are affected are not a major issue, but I want to known what made this error happen. Cause maybe next time other files are effected that I can't have being messed up.
I checked all disks for the smart statuses, everything passed. I got original HP ECC ram for the microserver which was ok when I installed the system. I'm running FreeNAS-9.3-STABLE-201511040813 .
I want to find the cause of the problem and take measures to prevent it in the future. Cause as probably many I use it as a backup system. Which I want to be able to count on.
Any help or thoughts are most appreciated.
BigDave
FreeNAS Enthusiast
Meaning they were all listed as:
Or are you saying there was a long history of short and long tests listed as:
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline  Completed without error  00%  9781  -
# 2  Extended offline  Completed without error  00%  9644  -
# 3  Short offline  Completed without error  00%  9542  -
# 4  Short offline  Completed without error  00%  9445  -
# 5  Short offline  Completed without error  00%  9390  -
# 6  Short offline  Completed without error  00%  8139  -
# 7  Extended offline  Completed without error  00%  8048  -
# 8  Short offline  Completed without error  00%  7982  -
# 9  Short offline  Completed without error  00%  7796  -
#10  Extended offline  Completed without error  00%  7656  -
#11  Short offline  Completed without error  00%  7553  -
#12  Short offline  Completed without error  00%  7457  -
#13  Extended offline  Completed without error  00%  7368  -
#14  Short offline  Completed without error  00%  7241  -
#15  Short offline  Completed without error  00%  7050  -
#16  Extended offline  Interrupted (host reset)  60%  6910  -
#17  Short offline  Completed without error  00%  6812  -
#18  Short offline  Completed without error  00%  6740  -
#19  Extended offline  Completed without error  00%  6655  -
#20  Short offline  Completed without error  00%  6334  -
#21  Extended offline  Completed without error  00%  6192  -
BigDave
FreeNAS Enthusiast
If you are convinced it's not a drive issue, test the RAM.
DrBobba
I'll do a full ram test, but first I'm copying the data to an other system. Which goes fine actually without any more errors. And without touching the effected files of course.
BigDave
FreeNAS Enthusiast
Good luck and let us know how you're getting along :)
jgreco
Resident Grinch
use sas drives, if your data is important.
This seems like a nonsensical suggestion. SAS and SATA drives differ primarily in the interface technology.
The real question here is why didn't redundancy kick in to allow the problem to be corrected. Are you not using RAIDZ2?
A RAIDZ2 setup with "unreliable" drives is a lot more reliable than a single half as "unreliable" drive.
