Hello All gurus of the SSH authentication.
I have been fine in the past with authentication. I am longer been able to authenticate when I ssh to the TN box or authenticate my RSYNC via my key. There were 2 changes that I have made. Change 1) upgraded from to 13.0-U5.1 from I believe was U2. 2) I stopped using SMB and CIFS and moved to just NFS as I want to retain my file structure. I suspect the later as I had made several changes to permissions. Access is from the LAN and not remote.
I had read several good suggestions of what to try, but I still have an issues (ha, don't we all :) ).
In the auth.logs I can see:
Authentication refused: bad ownership or modes for file /mnt/NAS_Drive_01/Backup/Familyroom/.ssh/
authorized_keys.
I can confirm that if I 'cat' that folder, the key does match what is in the GUI as well as the client machine's public key.
My dir's permissions settings:
drwxr-xr-x. Via CLI ls -l, he Gui seemed to not match.
I have stripped ACLs from the pool, set the Access mode to 755, and reset the user and the group and applied excursively. Under SSH settings I have removed password authentication and restarted the service ( and the VM as well )
I can view all dirs/files that are shared via NFS in the pool, I just cant authenticate via SSH or RSYNC.
Any additional check to try is much appreciated
Regards and thank you for your time
additional neat stuff:
jc@Living-room:~$ ssh -vv jc@192.168.50.155
OpenSSH_8.9p1 Ubuntu-3ubuntu0.1, OpenSSL 3.0.2 15 Mar 2022
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: include /etc/ssh/ssh_config.d/*.conf matched no files
debug1: /etc/ssh/ssh_config line 21: Applying options for *
debug2: resolve_canonicalize: hostname 192.168.50.155 is address
debug1: Connecting to 192.168.50.155 [192.168.50.155] port 22.
debug1: Connection established.
debug1: identity file /home/jc/.ssh/id_rsa type 0
debug1: identity file /home/jc/.ssh/id_rsa-cert type -1
debug1: identity file /home/jc/.ssh/id_ecdsa type -1
debug1: identity file /home/jc/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/jc/.ssh/id_ecdsa_sk type -1
debug1: identity file /home/jc/.ssh/id_ecdsa_sk-cert type -1
debug1: identity file /home/jc/.ssh/id_ed25519 type -1
debug1: identity file /home/jc/.ssh/id_ed25519-cert type -1
debug1: identity file /home/jc/.ssh/id_ed25519_sk type -1
debug1: identity file /home/jc/.ssh/id_ed25519_sk-cert type -1
debug1: identity file /home/jc/.ssh/id_xmss type -1
debug1: identity file /home/jc/.ssh/id_xmss-cert type -1
debug1: identity file /home/jc/.ssh/id_dsa type -1
debug1: identity file /home/jc/.ssh/id_dsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.1
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.8-hpn14v15
debug1: compat_banner: match: OpenSSH_8.8-hpn14v15 pat OpenSSH* compat 0x04000000
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 192.168.50.155:22 as 'jc'
debug1: load_hostkeys: fopen /home/jc/.ssh/known_hosts2: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,sntrup761x25519-sha512@openssh.com,diffie-he
llman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,ext-info-c
debug2: host key algorithms: ssh-ed25519-cert-v01@openssh.com,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01
@openssh.com,sk-ssh-ed25519-cert-v01@openssh.com,sk-ecdsa-sha2-nistp256-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-ed25519
,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ssh-ed25519@openssh.com,sk-ecdsa-sha2-nistp256@openssh.com,rsa-sha2-512,rsa-sha2-256
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.co
m,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.co
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-
debug2: host key algorithms: rsa-sha2-512,rsa-sha2-256,ecdsa-sha2-nistp256,ssh-ed25519
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,none
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,none
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ssh-ed25519
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ssh-ed25519 SHA256:TkHsbCQ6cDeT35nNEQe+PB1BhoNQgAw24lR26LcqgKI
debug1: Host '192.168.50.155' is known and matches the ED25519 host key.
debug1: Found key in /home/jc/.ssh/known_hosts:3
debug2: ssh_set_newkeys: mode 1
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug2: ssh_set_newkeys: mode 0
debug1: rekey in after 134217728 blocks
debug1: get_agent_identities: bound agent to hostkey
debug1: get_agent_identities: ssh_fetch_identitylist: agent contains no identities
debug1: Will attempt key: /home/jc/.ssh/id_rsa RSA SHA256:A989zQwpweT9a8Rk1gLfNn4mQsOGhKzWBAh8AliJYU0
debug1: Will attempt key: /home/jc/.ssh/id_ecdsa
debug1: Will attempt key: /home/jc/.ssh/id_ecdsa_sk
debug1: Will attempt key: /home/jc/.ssh/id_ed25519
debug1: Will attempt key: /home/jc/.ssh/id_ed25519_sk
debug1: Will attempt key: /home/jc/.ssh/id_xmss
debug1: Will attempt key: /home/jc/.ssh/id_dsa
debug2: pubkey_prepare: done
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,sk-ssh-ed25519@openssh.com,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-
sha2-nistp521,sk-ecdsa-sha2-nistp256@openssh.com,webauthn-sk-ecdsa-sha2-nistp256@openssh.com>
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /home/jc/.ssh/id_rsa RSA SHA256:A989zQwpweT9a8Rk1gLfNn4mQsOGhKzWBAh8AliJYU0
debug2: we sent a publickey packet, wait for reply
debug1: Trying private key: /home/jc/.ssh/id_ecdsa
debug1: Trying private key: /home/jc/.ssh/id_ecdsa_sk
debug1: Trying private key: /home/jc/.ssh/id_ed25519
debug1: Trying private key: /home/jc/.ssh/id_ed25519_sk
debug1: Trying private key: /home/jc/.ssh/id_xmss
debug1: Trying private key: /home/jc/.ssh/id_dsa
debug2: we did not send a packet, disable method
debug1: No more authentication methods to try.
jc@192.168.50.155: Permission denied (publickey).
authorized_keys.
debug2: reserved 0
debug2: reserved 0
