Kas Coenen
- Sep 15, 2013
I get an XML parser error when clicking on ZFS Volume Manager. I tried to reinstall the system to no avail. I already tried other cd's, cdrom drives, etc Here is backtrace:
Environment:
Software Version: FreeNAS-9.1.1-RELEASE-x86 (a752d35)
Request Method: GET
Request URL: http://192.168.1.50/storage/volumemanager/
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
109. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
165. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
25. return view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/storage/views.py" in volumemanager
147. for disk, info in notifier().get_disks().items():
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in get_disks
2861. disks = self.__get_disks()
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in __get_disks
4018. root_dev = self.__find_root_dev()
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in __find_root_dev
3991. doc = self.__geom_confxml()
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in __geom_confxml
3387. self.__confxml = libxml2.parseDoc(self.sysctl('kern.geom.confxml'))
File "/usr/local/lib/python2.7/site-packages/libxml2.py" in parseDoc
1271. if ret is None:raise parserError('xmlParseDoc() failed')
Exception Type: parserError at /storage/volumemanager/
Exception Value: xmlParseDoc() failed
Can anyone help me? My first install of freenas succeeded. But this one is giving me problems. This is a standaard install with no changes to the system. The os is installed on a hdd (already swapped the hdd and hdd kabel too rule out disk errors)
Kas
Environment:
Request Method: GET
Traceback:
Kas
