Brentnall
- May 24, 2015
My Google-Fu may be failing me here so feel free to take exception to this stupidity and point me in the right direction of an existing thread or bug listing :p
Assuming that isn't the case however here goes...
When attempting to delete any iSCSI extent I receive the following error at the GUI.
This is true of both file based or device based extents.
If anyone can advise of the command to remove an extent at the CLI I'll give that a go too.
As it stands however I am currently unable to remove iSCSI extents.
Adding a new extent or editing an existing extent works fine. I found a few FreeNAS bugs reported for adding extents but none for removing them unfortunately.
Any suggestions or is it time to submit a bug report?
Full Traceback output:
Environment: Software Version: FreeNAS-9.10.1-U2 (f045a8b) Request Method: GET Request URL: https://192.168.1.103/admin/services/iscsitargetextent/delete/10/ Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 105. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 156. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 22. return view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/options.py" in wrapper 208. return self._admin.admin_view(view)(*args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/utils/decorators.py" in _wrapped_view 99. response = view_func(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/views/decorators/cache.py" in _wrapped_view_func 52. response = view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/site.py" in inner 142. return view(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/options.py" in delete 832. form_i = form(instance=instance) File "/usr/local/www/freenasUI/services/forms.py" in __init__ 1915. targets_in_use = notifier().iscsi_connected_targets() File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in iscsi_connected_targets 6068. target = target_name.split(':')[1] Exception Type: IndexError at /admin/services/iscsitargetextent/delete/10/ Exception Value: list index out of range
