xhci1: Resetting Controller
jonathan0104
Hey
I am currently in the process of migrating from UnRaid to FreeNAS.
During install and after I encounter the following "code loop" as detailed below, this is a clean install with only the boot drives and "future" L2ARC drive connected.
Installed using BIOS mode. The only configuration I have completed so far is set Time Zone, Turn on Auto Tunables, and also add "xhci_load = YES" to the tuneables in order to try and resolve the issue.
After an exhaustive google the only hint I could find was "xhci_load = YES"
I would like to try and resolve this error before migrating my data back across. Any help is much appreciated.
Thanks
Jan 6 19:52:51 freenas ugen2.2: <vendor 0x2109 product 0x0810> at usbus2 Jan 6 19:52:51 freenas uhub8 on uhub2 Jan 6 19:52:51 freenas uhub8: <vendor 0x2109 product 0x0810, class 9/0, rev 3.00/33.88, addr 1> on usbus2 Jan 6 19:52:51 freenas uhub8: 4 ports with 4 removable, self powered Jan 6 19:52:52 freenas ugen2.3: <vendor 0x2109 USB2.0 Hub> at usbus2 Jan 6 19:52:52 freenas uhub9 on uhub2 Jan 6 19:52:52 freenas uhub9: <vendor 0x2109 USB2.0 Hub, class 9/0, rev 2.00/2.88, addr 2> on usbus2 Jan 6 19:52:53 freenas uhub9: 4 ports with 4 removable, self powered Jan 6 19:52:53 freenas uhub2: at usbus2, port 1, addr 1 (disconnected) Jan 6 19:52:53 freenas ugen2.2: <vendor 0x2109 product 0x0810> at usbus2 (disconnected) Jan 6 19:52:53 freenas uhub8: at uhub2, port 1, addr 1 (disconnected) Jan 6 19:52:53 freenas uhub8: detached Jan 6 19:52:53 freenas ugen2.3: <vendor 0x2109 USB2.0 Hub> at usbus2 (disconnected) Jan 6 19:52:53 freenas uhub9: at uhub2, port 3, addr 2 (disconnected) Jan 6 19:52:53 freenas uhub9: detached Jan 6 19:52:53 freenas uhub2: <0x1b21 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus2 Jan 6 19:52:53 freenas uhub2: 4 ports with 4 removable, self powered Jan 6 19:52:54 freenas xhci1: Resetting controller
Syem Specs:
  • ASUSTeK COMPUTER INC. P9X79 PRO
  • Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
  • 32Gib RAM
  • Boot Drives Crucial 120 GiB x2 (Motherboard SATA)
  • Samsung 860 Evo 1 Tib (Motherboard SATA)
  • Hard disk controllers - LSI SAS3224 (No Drives Connected)
  • Chelsio T520-CR Ethernet Card
  • Intel 82575GB Ethernet Card
  • NVIDIA GeForce GT710 Graphics Card
  • debug-freenas-20200106194350.tgz
jonathan0104
So after much messing about with the BIOS settings I have managed to stop the loop by disabling the USB 3.0 Controllers.
I am guessing there is a FreeBSD Driver Compatibility issue with the onboard USB 3.0 Controllers.
