- Oct 29, 2016
has anyone tried to boot from the onboard SAS on a x9srh-7f?
I got it to go in a proprietary, old isilon chassis, thinking i could just put some reverse break-outs on it, but it will not boot from the sas at all, there is no sign of it in the BIOS, and it does not give the "press ctrl-C to configure" prompt or anything. the expander *can* boot, I had an x9spu in it (cobbled together cuz UIO) and it booted from an LSI card.
it clearly works, as the drives are all available on a USB booted freenas.
I have updated everything, and the 2308 reports having the bios on it.
is there a setting or jumper somewhere I am missing? I have some x8dte's (they are what was in the s200, but they are so old the java barely works at all)
what I really need to know is, is this normal/possible to enable, or is the board faulty? its from ebay so if it's faulty i need to know.
it has a miniSATA carrier thing, but the damn thing doesn't fit with the breakout cables connected, miniSATA drives are a PITA to find, and I dont WANT the boot drive inside it.
isilon s200 (2u 24 bay, 2.5", with SAS expander 2x sff-8087
x9srh-7f
random 2.5"s
2x chelsio t320E
2x reverse break out cables (cables-to-go i think?)
truenas 12u8 (on a USB, but booting from USB makes ikvm input not work, also super annoying)
any ideas?
x9srh-7f
random 2.5"s
2x chelsio t320E
any ideas?
