Hi all,
Struggling to find specifics, wondering if anyone has used the Supermicro X11SCM-F? https://www.supermicro.com/en/products/motherboard/X11SCM-F
From it's specs (and I've read this: https://www.ixsystems.com/community...-supermicro-x11-xeon-e-coffee-lake-board.107/), I should be able to use the M.2 ports (x2) for my boot SSDs, then the full 6x SATA ports for storage drives (RaidZ2 has a nice number for 6 disks).
My main question is, does anyone know if use of both M.2 slots eliminate the use of any of the SATA ports? Seems you get a SATA lane with the first M.2 port, and I can't be losing any of the 6 SATA ports.
I know the guide suggests the board is cost reduced etc, but we really have only one half way decent Supermicro supplier in New Zealand, and their range is severly limited. Trying to get 8 sata ports plus IPMI at any semi decent price is hard... I've stopped using USB sticks after constant issues on the first build (all Sandisks). This is my third build. My last build was an X11SSL-CF which had the LSI3008, so I could get around it - of course, that's not in stock any more.
Last option would be an X11SCL-F (cheapest IPMI) then add an AOC-S3008L-L8e to get enough SATA. Actually one of the advantages of the SCM-F means raid'd boot on motherboard, so I only need space for 6 disks, not 8.
