Kevin Horton
 - Dec 2, 2015
I'm assembling a server with an X10SRH-cF board and an E5-1620-v4 CPU.  I've got a couple of problems/questions:
1. RAM compatibility: I ordered two 16GB Samsung M393A2G40DB0-CPB RAM modules, which is on the approved memory list. I recieved Samsumg M393A2G40EB1-CPB0Q, which is not on the list. I have not yet found any info on whether these two part numbers are in fact equivalent. Do anyone have any info on whether this RAM is expected to be compatible or not? I have queries in with the RAM vendor and Supermicro, but have not heard back yet.
2. The board shows up on IPMI, but will not boot. I select Power ON via IPMI, but nothing seems to happen. I see nothing in the KVM console. The IPMI sensors info shows nothing for any voltages, temperatures, etc. I have tried with the board sitting on cardboard, to ensure nothing is shorting out the back, but I get the same result. Is this an expected result if I have bad or wrong RAM, or does this indicate another problem? I've asked this question to Supermicro, but have not heard back yet.
Thanks for any info.
Kevin
Kevin
