Hi, I've recently set up my own NAS system, I've followed the freenas8.2 guide and everything works except that I'm getting ridiculously low write/read speed.
As of currently when I'm writting to the NAS device I'm getting a write speed of about 1MB/sec and read of 1,5MB - 2MB/sec. This is just absolutely dreadful and I should be getting more.
Here's the system info :
Mobo : Asrock P4VM890
PCU : Old Pentium 4 1.6 GHz
PSU : generic 300W
RAM : 1GB DDR 400
HDD : 2x WD RE4 500GB(brand new)(capable of 125 MB/sec)
File format : UFS
controller : Software Raid 1 through FreeNAS
Ethernet : 10/100
FreeNAS installed on : Corsair 4GB USB key
So far I've tried different ethernet cables, I've also connected NAS to a completely different network with a different router/modem and tested it there, same results which means the problem is NAS hardware related.
I initially thought the onboard ethernet RJ45 port is not working properly and I had a Realtek 10/100 Ethernet PCI card lying around, results were slightly better, talking about very minor increase in speed.
Has anyone had similar problems? I can't figure it out how to increase the write/read speed ...
PSU : generic 300W
RAM : 1GB DDR 400
File format : UFS
Ethernet : 10/100
