Will this Memory. Processor, and Motherboard Work Together
slimknot
I have the following memory and processor and would like to find an “inexpensive” motherboard to use with it.
Memory M393B1K70DH0-CH9 – Samsung 4 x 8GB DDR3-1333 RDIMM PC3-10600R Dual Rank x4 Modules
Processor Intel Xeon E5-2690 https://ark.intel.com/products/6459...E5-2690-20M-Cache-2_90-GHz-8_00-GTs-Intel-QPI
Will this Supermicro motherboard work?
MBD-X9SRL-F https://www.supermicro.com/products/motherboard/Xeon/C600/X9SRL-F.cfm
The memory is not listed as compatible but it was removed from another Supermicro (X9DRi-LN4F+) motherboard.
If this motherboard will not work, please point me to some motherboards that may work.
Thank you!
BigDave
FreeNAS Enthusiast
You need to do your own research because the way you are going about this is kinda backwards, typically you find a board, then a CPU, and THEN search for RAM that works with them.
I seriously doubt the RAM you have is going to work in a SINGLE CPU board of any kind, but I wish you luck in your searching.
Once you find a match between board/cpu/memory we can help verify compatibility for you.
Chris Moore
Thank you!
The specific module you have is not listed, but it is correct kind of memory.
No guarantee, but it should work.
You don't need a dual socket board to use registered ECC.
slimknot
Thank you.
The memory does work fine with that motherboard and processor.
