thetraveller333
- Nov 19, 2012
I lost over 500 GIG of pictures and videos not too long ago and I promised myself that it will never happen again, so in addition to bluray backups, I'm building this Raid NAS. Performance is not as important as reliability.
This is what I have so far:
Case: Antec Nine hundred, ATX Mid tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
Mother board: ASUS P8Z77-V
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131820
Power Supply: Corsair Professional Series Gold AX750
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139016
RAM: 16 GB Corsair Vengeance 16 dual channel kit DDR3 1600 MHZ
http://www.amazon.com/dp/B004E0ZKLQ/?tag=ozlp-20
USB 3.0 stick for OS: 8GB Patriot Supersonic Boost XT
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220652
USB 3.0 external to internal 19 pin adapter cable
http://www.newegg.com/Product/Product.aspx?Item=N82E16812162012
Hot Swap drive cages: iStarUSA 3X5.25in to 4X3.5in SAS/SATA, model #BPN-DE340SS-Blue
http://www.directron.com/bpnde340ssblue.html
Hard Drives: 8X WD 3TB Red
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236344
Notes:
I don't have an optical drive, but I can add one if needed.
I would like to use RAID-Z2 for greater reliability.
I bought 9 drives, at two different times and from two different vendors; 8 for the NAS and 1 for when one of the 8 fails.
Questions:
1. One of the missing pieces to the puzzle is an HBA. I would like to take advantage of the PCIE 3.0 on the mother board and the only HBA I found that is compatible with PCIE 3.0 is the LSI SAS 9207-8i. (http://www.provantage.com/lsi-logic-lsi00301~7LSIG0N3.htm?source=googleps) What do you think of this card for my setup? I read that FreeNAS works better if it has direct control of the drives, so going through a hardware raid card doesn't make sense.
2. Is it better to use a USB stick or an SSD for the OS? (I have a 64 GB Crucial SSD that I can use)
3. I have room for 4 more drives in the case. Could I add another 4 drives later or is it better to add them now, together with another HBA? (I have a lot of pictures)
Any advice or suggestions would be greatly appreciated.
Thank you for your help
Notes:
Questions:
