Why size available is small? 3TB x (3+1) RAIDZ
moto
Hi everyone,
I will use for the first time Freenas , but in trouble not know the correct information .
I used freenas 9.3. I've built a zpool(RAIDZ1) by 4drives (3 TB each).
I have created a disk pool and it shows 10.9TiB which is correct by my calcs.
But the RAIDZ dataset shows as 7.7TiB whereas I was expecting it to be closer to 8.2TiB.
Please tell me what reason is this difference(near 500GB) .
Also, what is a way to enable all of the area?
# zpool list
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
zfs1 10.9T 5.80M 10.9T - 0% 0% 1.00x ONLINE /mnt
# df -h /mnt/zfs1
Filesystem Size Used Avail Capacity Mounted on
zfs1 7.7T 139k 7.7T 0% /mnt/zfs1
Bidule0hm
Server Electronics Sorcerer
It's because of the overheads of ZFS and it's normal, you can't do anything to "correct it" :)
As an aside it's not recommended to use RAID-Z1 with drives of more than 3 TB (unless this is a backup server and you can tolerate a lower reliability), see the "don't use RAID-Z1" link in my signature to know why.
df and du are not appropriate tools for ZFS mounted partitions...
And if you understand RAIDZ1, you go from 12TB raw to 10.9T formatted, then lose approximately 1/4 because RAIDZ1 uses a disk for redundancy.
So nothing to see here. :P
moto
thanks for the reply.
I know that one drive used to parity by RAIDZ.
My calculation is as follows .
3TB disk = 3,000,000,000,000 bytes
3,000,000,000,000 bytes = 2.73 TiB
4 x 2.73TiB = 10.9TiB (It is disk pool size. It is correct.)
So , my expectation is
10.9TiB * (3/4) = 8.2TiB (My Expected dataset size)
But, dataset shows as 7.7TiB...
You still have to factor in the overhead that @Bidule0hm was talking about.;)
moto
Thank you all!
It seems overhead is greater than I had thought .
SweetAndLow
Sweet'NASty
If you are worried about 500GB you should also take into account that you shouldn't fill your pool past 80% full and never past 90%. So you get between 6.2TiB and 6.9TiB.
