Robert Thomspon
- Jun 24, 2017
Hey guys... fighting myself on what to do...
I currently have a Dell T7500 w/ 1x Xeon X5667 and 48GB of DDR3 ECC RAM, with 4x8TB Seagate Barracuda drives running past a RAID card flashed to run simple SATA 6GB/s (The T7500 is natively SATA 2... so the card in theory makes my drives faster... )
Anyway, I happen to have a spare rig from helping my brother build a better gaming rig...
Ryzen 5 1600, 16GB DDR4 (NOT ECC) (2x8GB sticks) and a Gigabyte GA-AX370 board (not the best out there... and kind of a PITA if i wanted to run true RAID... but I dont :)
I would lose the add on Video Card the T7500 needs, as well as probably the RAD/SATA card as the Gigabyte is natively SATA 3...
Anyone have recommendations on which I should use? (Both are roughly the same in power usage... both processors are 95W... The AMD would probably run a few Watts lighter as no need for add on Video or SATA)... The AMD should be significantly faster on processing... but I dont have the same amount of RAM (The T7500 shows 36GB of RAM (WIRED under reporting) as always in use (1.1GB min, 32,6GB Avg, 36.7GB Max... again, all as "WIRED"
... but always less than 500MB used as ACTIVE (4.4MB min, 978MB average, 5.5GB Max))
