flyinglotus1983
- Apr 30, 2019
My FreeNAS is insanely slow. This is my first NAS so I'm not even sure what to expect for transfer speeds. I originally built it with 3x 8TB's in RAIDZ1. That was around 20 MB/s maybe? I recently added 3x 500GB SSD's in a new pool/vdev, and it's faster, but not significantly. Somewhere around 40 MB/s.
Honestly I don't even really need the capacity on the hard disk array. I'm not a data hoarder. I'm mostly just using it as a central file server that all of my laptops and PCs around the house can get to, and so that I can do distro hopping. I need speed more than I need capacity, basically.
Motherboard: Supermicro X8DTL-iF (dual LGA-1366, Intel 5500, ICH10R + IOH-24D, Intel 82574L gigabit Ethernet). Only supports SATA II.
CPUs: 2 x Xeon E5520 (4-core / 8 threads, 2.26 GHz)
RAM: 96GB (6x16GB) DDR3 PC3-8500R 4Rx4 ECC
LSI 9201-8i HBA in IT mode with latest firmware
Case: Rosewill 4U with 12x hot-swap bays
Hard drives: 3x 8GB (2 are shucked WD Elements / HGST, and 1 is a WD Red), ZFS RAIDZ1
SSDs: 3x 512GB SATA III (1 Silicon Power, 1 Samsung EVO 860, and 1 Pioneer APS-SL3N-512), ZFS RAIDZ1
FreeNAS: 11.2-U2
Shares to clients via SMB
I think the 8TB pool is going right to the Supermicro and the 500GB pool is going to the LSI card.
When I use iperf, I can get near perfect speeds between the FreeNAS server and a client linux PC.. 850+ MB/s if I recall correctly. I'm happy with that. It's not a network bottleneck.
So this is probably a dumb question, but where's my bottleneck? What would be the best use of my money for upgrades?
FreeNAS: 11.2-U2
