What the smart message mean?
Fei
Hi
Today, I upgrade my freenas to 9.3.1 latest , the system show critical alert after reboot.
[root@160nas] /usr/local/etc# cat /var/log/messages |grep smart
Apr 13 00:20:03 160nas smartd[2586]: Device: /dev/ada4, FAILED SMART self-check. BACK UP DATA NOW!
Apr 13 00:20:03 160nas smartd[2586]: Device: /dev/ada4, Failed SMART usage Attribute: 5 Reallocated_Sector_Ct.
Apr 13 00:20:03 160nas smartd[2586]: Device: /dev/ada2, 2 Offline uncorrectable sectors
I check my pool , it don't have any problem,so what the message mean?
pool: vol
state: ONLINE
  scan: scrub repaired 0 in 7h28m with 0 errors on Sat Apr  2 04:15:08 2016
        vol                                             ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            gptid/5d30fdd7-0668-11e4-8362-6805ca089be0  ONLINE       0     0     0
            gptid/5d98120a-0668-11e4-8362-6805ca089be0  ONLINE       0     0     0
            gptid/5decc3f1-0668-11e4-8362-6805ca089be0  ONLINE       0     0     0
            gptid/5e524f24-0668-11e4-8362-6805ca089be0  ONLINE       0     0     0
errors: No known data errors
Bidule0hm
Server Electronics Sorcerer
ada2 and ada4 are starting to have bad sectors. Usually a few bad sectors isn't a problem but if the number rise you'll want to replace the drives ;)
However as you have a RAID-Z1 you can't afford to have two drives failing at the same time so replace ada4 (as it seems in a worse state than ada2) before it's too late. I hope you have a backup of your data just in case.
The output of smartctl -a adaX for each drive would be useful to be more precise/confirm the answer :)
The messages mean exactly what they say: ada4 has failed a SMART self-test and has too many reallocated sectors, and ada2 has two offline/unreadable sectors. You need to replace ada4 immediately, and should keep an eye on ada2. There's no reason you should expect that this would show up in your pool status--it could, but it's also possible that the bad sectors are in locations with no data at the moment.
Fei
Hi
I running samrtctl -a ada2 & ada4 .
  • ada2.txt
  • ada4.txt
Bidule0hm
Ok, ada4 is failing hard, almost 2k reallocated sectors...
No SMART test has ever run on these drives; did you setup the tests in the web GUI?
Then I wanted to know why two drives with less than 6k POH are failing when I saw that: 194 Temperature_Celsius 0x0022 082 080 000 Old_age Always - 70 I can say you're probably the winner of the hottest drives I saw on this forum... The drives should be kept under 40 °C, note that 5 or 10 °C more is very concerning and yours are 30 °C more than that... You should stop the server right now and re-think the thermal design because with a 4x 3 TB RAID-Z1 you'll probably loose your data more or less soon.
Next time you post SMART results, please just post them inline in code tags, rather than as attachments. Other than that, what @Bidule0hm said--you've got major problems:
  • You're cooking your drives. You need to get your server out of the attic, get proper airflow, and get the drives cooled right down. Point a household fan at the server, if that's the best you can do. It may be too late for the drives that are in there, but it'll still pay dividends for the replacements.
  • You need to configure the SMART service to email you alerts, and to warn at a sensible level (i.e., not more than 40 C) for temperature.
  • You need to schedule regular SMART tests, as these drives have never seen one. I run a short test daily and a long test weekly; you could go as long as a short test weekly and a long test monthly.
Run long SMART tests on all your drives ('smartctl -t long /dev/adaX'). Once those finish (about 6-8 hours), post the results of 'smartctl -x /dev/adaX' for each drive, inline, in code tags.
Fei
When I running 'smartctl -t long ' test ,How to check this test is done ?
gpsguy
Active Member
If you run smartctl -a /dev/adaX
and look at the summary info near the end, the test will say completed if it's finished.
Fei
Hi
I power-off my freenas and add a internal SAS HBA to enhance disk I/O(3Gb -> 6Gb) , so fail disk number was change.
ada2 -> da1
ada4 -> da2
Apr 13 11:38:52 160nas smartd[8655]: Device: /dev/da2 [SAT], FAILED SMART self-check. BACK UP DATA NOW!
Apr 13 11:38:52 160nas smartd[8655]: Device: /dev/da2 [SAT], Failed SMART usage Attribute: 5 Reallocated_Sector_Ct.
Apr 13 11:38:52 160nas smartd[8655]: Device: /dev/da2 [SAT], previous self-test completed with error (unknown test element)
Apr 13 11:38:52 160nas smartd[8655]: Device: /dev/da1 [SAT], 2 Offline uncorrectable sectors
Smart test result as below, I found many error so I will replace these disk .
smartctl -a /dev/da1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build)
Model Family:     Western Digital Black
Device Model:     WDC WD3001FAEX-00MJRA0
Serial Number:    WD-WMC130049225
LU WWN Device Id: 5 0014ee 0036b2aed
Firmware Version: 01.01L01
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Size:      512 bytes logical/physical
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Apr 13 22:49:35 2016 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        been run.
data collection:                (35040) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 380) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x70b5) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   163   145   021    Pre-fail  Always       -       10841
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       494
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       5958
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       494
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       75
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       418
194 Temperature_Celsius     0x0022   091   080   000    Old_age   Always       -       61
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       2
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%      5957         -
# 2  Extended offline    Aborted by host               90%      5947         -
[root@160nas] ~# smartctl -a /dev/da2
Serial Number:    WD-WCC130244440
LU WWN Device Id: 5 0014ee 207edb281
Local Time is:    Wed Apr 13 22:51:11 2016 CST
SMART overall-health self-assessment test result: FAILED!
See vendor-specific Attribute list for failed Attributes.
Self-test execution status:      (  73) The previous self-test completed having
                                        a test element that failed and the test
                                        element that failed is not known.
data collection:                (35100) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 381) minutes.
  3 Spin_Up_Time            0x0027   179   165   021    Pre-fail  Always       -       10041
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       501
  5 Reallocated_Sector_Ct   0x0033   133   133   140    Pre-fail  Always   FAILING_NOW 1966
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       5959
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       501
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       82
194 Temperature_Celsius     0x0022   092   080   000    Old_age   Always       -       60
196 Reallocated_Event_Count 0x0032   166   166   000    Old_age   Always       -       34
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       18
ATA Error Count: 30 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 30 occurred at disk power-on lifetime: 5313 hours (221 days + 9 hours)
  ER ST SC SN CL CH DH
  40 51 b0 cb 66 41 e0  Error: UNC 176 sectors at LBA = 0x004166cb = 4286155
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  c8 00 b0 c0 66 41 e0 00      05:48:36.910  READ DMA
  c8 00 b0 c0 66 41 e0 00      05:48:36.786  READ DMA
  c8 00 b0 c0 66 41 e0 00      05:48:36.661  READ DMA
  c8 00 b0 c0 66 41 e0 00      05:48:36.536  READ DMA
  c8 00 b0 c0 66 41 e0 00      05:48:36.376  READ DMA
Error 29 occurred at disk power-on lifetime: 5313 hours (221 days + 9 hours)
  c8 00 b0 10 66 41 e0 00      05:48:36.375  READ DMA
Error 28 occurred at disk power-on lifetime: 5313 hours (221 days + 9 hours)
  c8 00 b0 60 65 41 e0 00      05:48:36.374  READ DMA
Error 27 occurred at disk power-on lifetime: 5313 hours (221 days + 9 hours)
  c8 00 b0 b0 64 41 e0 00      05:48:36.374  READ DMA
Error 26 occurred at disk power-on lifetime: 5313 hours (221 days + 9 hours)
  c8 00 b0 00 64 41 e0 00      05:48:36.373  READ DMA
# 1  Extended offline    Completed: unknown failure    90%      5951         -
# 2  Extended offline    Completed: unknown failure    90%      5949         -
# 3  Extended offline    Completed: unknown failure    90%      5948         -
# 4  Extended offline    Completed: unknown failure    90%      5948         -
# 5  Extended offline    Completed: unknown failure    90%      5948         -
# 6  Extended offline    Completed: unknown failure    90%      5947         -
Edit: A SAS HBA certainly won't hurt anything, but it won't really benefit you when using spinning rust. We already knew that da2 (the former ada4) was bad, and now it has a failed SMART self-test to confirm it. da1 (the former ada2) doesn't look too bad except for the temperature.
Fei
Hi danb35
If da1 smart test is normal , so I can ignore da1 error message from Web Gui (Alert System) ?
Two offline sectors doesn't (IMO) mean the drive needs to be replaced right away, but you should keep an eye on it. If the number starts climbing, you'll want to replace it.
Your last SMART results show the temperatures are lower, but still way too high.
Fei
Thanks your response .
The temperature issue I will improve it.
