Chris Moore
- May 2, 2015
I will try to get some better metric for you when I am back at work tomorrow.
using consumer drives in our NAS and that was the biggest mistake in the build
That's interesting to me too. I haven't bought an UPS yet and I'm wondering whether I can buy a smaller UPS instead of using the same measure as for the PSU.wait till the drives are in and test the draw
(Assuming a system with no staggered spin-up - my rig will have 7-9 hddshow many amps of power is this thing pulling?
The fine folks over at 45Drives have some pretty good info. So, here, they have a chassis with 45 drives, all spinning up "simultaneously".
when the system first spins the drives up, but it settles down fairly quick. I would say that you want to have some extra capacity above what I said
The same guidance applies for a UPS:That's interesting to me too. I haven't bought an UPS yet and I'm wondering whether I can buy a smaller UPS instead of using the same measure as for the PSU.
That Storinator chart seems to suggest that the drives are in fact staggered, whether they intended them to be that way or not.
Using the closest current APC model to mine, their runtime chart says that at full load, it will last 3 minutes. If you're planning on having the system immediately shut down on power loss, sizing the UPS based on your running system load (I agree, startup demands really shouldn't be a factor, as you aren't going to be starting up your system on battery) could work. But if you want capacity to keep your system up for a bit, the VA rating of the UPS will be nearly meaningless--size it based on the manufacturer's runtime chart.
if power is unstable or out for more than 60 seconds, expect that there may be a crew that needs to be dispatched to remediate.
In many cases, the UPS just needs the hold the load long enough for the generator to spin up.
