What is permission 0777? and how do I fix it?
I keep getting the error "[EFAULT] Exception: CallError:[EFAULT] pkg error: - pkg-static: /var/db/pkg permissions (0777) too lax Please check your network occured, destroyed plex." any time I try to install plex on freenas 11.2-U2.1
How do I fix this? I have been having problems with plex since the update to 11.2, such as with fetching data, then plex would not start, and now this
(And before I get told to check the update notes about this and to follow the instructions, I have, it does not fix it in my case)
Apollo
D
dlavigne
Guest
Was this a fresh install or an update from the 11.1 series?
Lazulitone
Bingo! I am also having issues with permissions on 11.2. Seemingly unable to change permissions on iocage jail.
