Having Plex Issues
csearle
So has anyone come across this issue when installing PLEX
[EFAULT] Exception: CallError:[EFAULT] pkg error: - pkg-static: /var/db/pkg permissions (0777) too lax Please check your network occured, destroyed plex.
Jailer
Not strong, but bad
Did you change permissions on your jail dataset?
csearle
What I have done is gone into
System>System Datasets
I changed the System Dataset Pool to the drive where the jail were..
I get the following error
[EFAULT] Exception: UnboundLocalError:local variable 'bridge_cmd' referenced before assignment occured, destroyed plex.
nojohnny101
Please search before posting. This issue is outlined in previous threads and is mentioned in the specific release notes for 11.2 U-2 (which can be found here)
