Emby installation fails
DD4711
I'm trying to install emby plugin, but it fails:
Install
[EFAULT] Exception: CallError:[EFAULT] pkg error: - pkg-static: Repository iocage-plugins load error: access repo file(/var/db/pkg/repo-iocage-plugins.sqlite) failed: No such file or directory pkg-static: http://pkg.cdn.trueos.org/iocage/11.2-RELEASE/meta.txz: Protocol not supported pkg-static: http://pkg.cdn.trueos.org/iocage/11.2-RELEASE/packagesite.txz: Protocol not supported Please check your network occured, destroyed emby.
I can wget both files from freenas server.
Does someone have those issues, too?
I'm using FreeNAS-11.2-U6.
I had the same issue lasting about 2 days. It then "fixed" itself. Seems to be a transient error but I could not determine if it was on the FreeNAS end of things (like you, I could nslookup the source address, wget the actual file outside of the jail) or on the repoistory itself.
DD4711
Hello Newfoundland.Republic,
thanks for reply! Today I tried it again and it worked. Seems to be same temporary problem as you had...
