what is path to transmission jail in transmission shell?
cudencuden
Launched the shell of my transmisison jail to be able to run transmission-create...
so, if my configured jail root in freeNas transmission plugin is "/mnt/files/jails"
how do you get to this path from jail's shell?
i'm basically getting invalid path when trying to use transmission-create
SweetAndLow
Sweet'NASty
Not sure what transmission create is but you probably need to give it a file and I'm assuming you want a file from your zfs pool. Where did you mount your data in the transmission jail? This can be found under the transmission jail and add storage section. Whatever the dest path is, is the path in the jail where your data lives.
pirateghost
Unintelligible Geek
You don't access the jails dataset directly from the jail. You attach storage to it (another dataset on the pool)
cudencuden
everything works fine..i download using webgui fine to jail.storage...jail source is /mnt/files/jails/transmission_1/mnt ..but in transmission's jail shell...how do i get to my files in the jail??? if i do "ls /mnt/files/jails/transmission_1/mnt" i get "no such file or directory"
pirateghost
Unintelligible Geek
Please show a screenshot of your jail storage configuration for this jail.
You should not be mounting the jails dataset as jail storage. That's redundant.
You should have a 'downloads' dataset somewhere. add storage to the jail and have it be the source, and the destination will be relative to the jail root ('/'). I would pick /media/downloads as my destination.
Then in the jail, everything is downloaded to /media/downloads, and it is actually being downloaded to /mnt/files/downloads (the path on FreeNAS, not the jail)
cudencuden
ohh no..i changed the destination from /media to /Downloads....and now all my jail storage files can't be found..it's still there but idk where they went...they are no longer in Downloads folder nor media folder from screenshot
pirateghost
Unintelligible Geek
you're trying to mount the jail itself as storage to itself. This doesn't work.
http://doc.freenas.org/9.3/freenas_jails.html#add-storage
  • Source: is the directory or dataset on the FreeNAS® system you would like to gain access to from the jail. This directory must reside outside of the volume or dataset being used by the jail. This is why it is recommended to create a separate dataset to store jails, so that the dataset holding the jails will always be separate from any datasets used for storage on the FreeNAS® system.
  • Destination: select an existing, empty directory within the jail to link to the “Source” storage area. If that directory does not exist yet, type in the desired directory name and check the “Create directory” box.
cudencuden
understood..but now..i just want to know where the files i had in my jail storage went....the 1.9 TB used..idk where the files are now...i tried searching for one of the files at the top level...nothing found
pirateghost
Unintelligible Geek
from FreeNAS CLI, it is in /mnt/files/jails/transmission_1/mnt, based on your original information. Since you didn't show me your ORIGINAL configuration I couldn't say for sure. First thing you need to learn is what you are doing. You went and changed some files around and had no idea what it was doing.
cudencuden
yes. so sorry..so dumb of me... the original config is that Source = /mnt/files/jails/transmission_1/mnt , Destination = /Downloads ....I changed Destinations = /media ....what can i do to get the files out of jail...i just want the files now lol..
pirateghost
Unintelligible Geek
then FROM THE FREENAS CLI (not the jail), files would be located in /mnt/files/jails/transmission_1/mnt
you would be better off creating a new dataset in FreeNAS, then using the command line to copy all the files from the original location to the new dataset, then mount the new dataset as your storage in your jail.
cudencuden
hmmm....from freenass cli: i went to /mnt/files/jails/transmission_1/mnt and did "ls" nothing showed up...even cd .. and went back into the folders, media, Downloads (where they files were)...
pirateghost
Unintelligible Geek
From FreeNAS cli,
cd /mnt/files/jails/transmission_1
Do you know the name of a file that is located in your downloads?
find . -name "*<nameoffile>*" -exec echo {} \;
It will print out the path of that file
Also, STOP USING THE CRAPTACULAR WEB SHELL.
Use SSH (PuTTy if on Windows, terminal if on Mac, any terminal emulator/shell on Linux)
cudencuden
yes, i tried searching for God of War (USA).7z not nothing was in result
pirateghost
Unintelligible Geek
You can try it from '/' instead of inside the jail path, but it my take a while depending on how many files you have on your server.
cudencuden
yes, thansk for the puTTY reminder..much better...i searched from '/' ...but nothing relevant showed up...am i screwed? i'm holding on to hope because storage says 1.9TB used....is it just hidding or something idk lol
SweetAndLow
Sweet'NASty
cudencuden
i restarted transmission service and files reappeared...so happy hahahahahahah...thanks pirateghost....thanks sweetandlow
