What is holding the transfer speed?
melloa
Folks,
While waiting on my switch to get here, i run some tests and noticed the rsync transfer speed just a little bit faster over 10gb than over 1gb.
Both servers are using Chelsio 10GB 2-Port PCI-e Card PCI-E 110-1088-30, connected with a Cisco SFP-H10GB-CU1M 1 Meter Twinax 10GB Cable, both servers are using X9DRi-LN4F+/192GB, and the Chelsios are passed through to the ESXi 6.5 VMs.
1Gb NIC is on 10.10.10.0/24 and the 10Gb NIC is on 10.10.99.0/24:
iperf test run from server 1 to server 2
iperf -s
Server listening on TCP port 5001
TCP window size:  256 KByte (default)
[  4] local 10.10.99.2 port 5001 connected with 10.10.99.1 port 26554
[ ID] Interval	   Transfer	 Bandwidth
[  4]  0.0-10.0 sec  11.5 GBytes  9.90 Gbits/sec
[  5] local 10.10.10.220 port 5001 connected with 10.10.10.200 port 48511
[  5]  0.0-10.0 sec  1.10 GBytes   942 Mbits/sec
rsync between both through the 10Gb NICs:
4,908,552,205 100%   46.84MB/s	0:01:39 (xfr#1, ir-chk=2422/79826)
dd on receiver side server:
dd bs=256k if=/dev/da0 of=/dev/null
131072+0 records in
131072+0 records out
34359738368 bytes transferred in 41.311843 secs (831716427 bytes/sec)
rsync command:
rsync --delete --progress -rltuv root@10.10.99.1:/mnt ./
Understand rsync does more than copy, so I'd expect not get 10Gb transfer, but it is the 46MB/s normal?
You're using rsync over ssh here (because of the colon in the command), which means the comms are encrypted... perhaps contributing something to the slowness.
Try it without the colon...
Like this
rsync --delete --progress -rltuv root@10.10.99.1/mnt ./
melloa
rsync is notoriously slow.
Agree. Was just expecting a little improvement.
I would do a cp from the same systems and compare the speed differences.
There is no comparison. A 1.4 GB files rsync'ed in 29 secs. The same file was copied internally in less than 2 secs, but that's also expected as cp copied locally.
1,406,838,780 100%   45.68MB/s	0:00:29 (xfr#12, ir-chk=2591/79876)
Never saw that syntax. The shell didn't like is either :) It seems to "think" is copying within the same machine:
sending incremental file list
rsync: change_dir "/root@10.10.99.1" failed: No such file or directory (2)
sent 20 bytes  received 12 bytes  64.00 bytes/sec
total size is 0  speedup is 0.00
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1180) [sender=3.1.2]
Arwen
If they are on local network, why not setup a Rsync share on the source, and use something like this on the destination;
rsync -aHSXx --delete --progress rsync://SOURCE_IP/SHARE_NAME/ /mnt/NEW/LOCATION/
Yes, Rsync is slower than straight copy. Especially over SSH.
But, for me, I like the fact that Rsync can copy an entire tree of files, but interruptable. Using cp -r or mv are not interruptable. Meaning they leave either the destination, (for cp -r), or both source and destination, (for mv), in an undetermined state if interrupted.
melloa
Never used. Will test it, thanks.
Yes, agree, great tool. If it only was faster ;)
Pabs
Hi, having the same issue, 1gbps performance over a 10gbps link, FreeNAS on a side, QNAP on the other.
Iperf shows
[ 3] 0.0- 1.1 sec 887 MBytes 6.49 Gbits/sec
Yet rsync is waaay slower than that.
Are there any updates or work around for this?
thx
