SOLVED What is a proven good 8gb x4 ram module for Asrock C2750D4I?
skimon
Im having a lot of trouble finding any info on what is known good ram for this mother board C2750D4I . I found some evidence that the Kingston KVR16E11/8I works with it but of course that doesnt necessarily mean that its good/ ok . Also I have heard that Kingston are not to be trusted.
I also checked the vendor list on the asrock QVL list but i could not find any of the listed parts on newegg/tigerdirect/amazon.
I suppose another way to ask it may be - what does the freenas mini use? :P
Thanks!
mjws00
Cyberjock's mini shows Samsung m391b1g73bh0-ck0.
I believe Crucial is also on the QVL, but I've never looked into it.
ilmarmors
I'm using 2 x 8GB Crucial CT10247BD160B modules in my ASRock C2750D4I. No problems so far, but I have been running it for 2 weeks only, and it is not 4 x 8GB setup you are looking confirmation for.
It is on ASRock Memory QVL - www.asrockrack.com/general/productdetail.asp?Model=C2750D4I#Memory%20QVL
And you can buy it on Amazon as:
Or you can buy it from Crucial - www.crucial.com/usa/en/ct102472bd160b
skimon
thank you all for the replies. I dont see the samsung on the QVL list . I do see the crucial though so i will most likely go with that.
Top Bottom
