SOLVED What have I done wrong: Jail, synching slowness, ? vnet
Tim1962
I've had a generally stable TN (Spec in sig block) with several jails (two plugins) had had to refresh my separate hardware pfSense (though don't know I changed anything significant...)
I've been trying to install synching, firstly as a plugin (no joy, VNET failures all round - research all seems to relate to 2-3yrs ago of issues, nil recently though), so swapped to installing via a jail. Base is 13.0. DHCP, (few trials and errors but eventually working)
Installed via pkg, syncthing and although that took a while, seems successful. However syncing is like treacle.
Also a separate (new) Windows10 VM is pretty slow too
SO what would be helpful...
last pid: 11783;  load averages:  1.07,  1.05,  0.98    up 4+03:07:14  16:03:18
113 processes: 1 running, 111 sleeping, 1 zombie
CPU:  0.7% user,  0.2% nice, 25.8% system,  0.0% interrupt, 73.3% idle
Mem: 8499M Active, 5838M Inact, 25M Laundry, 16G Wired, 1146M Free
ARC: 13G Total, 7343M MFU, 4539M MRU, 7876K Anon, 116M Header, 812M Other
     11G Compressed, 16G Uncompressed, 1.49:1 Ratio
Swap: 4096M Total, 4096M Free
System Processes
  PID USERNAME    THR PRI NICE   SIZE    RES STATE    C   TIME    WCPU COMMAND
11342 root         22  20    0  8275M  1691M kqread   0  11:39 100.49% bhyve
11269 root          1  21    0   239M   198M kqread   0   1:11   1.99% smbd
10770   1001       15  29    9   812M   136M uwait    3   3:05   1.43% syncthin
  521 root         35  20    0   600M   406M kqread   2  16:14   0.57% python3.
 3773    972       13  52   15   114M    77M piperd   0   9:28   0.04% Plex Scr
11775 root          1  20    0    14M  4292K CPU2     2   0:00   0.02% top
87139 root          1  20    0    15M  2488K zcw->z   1   0:12   0.02% cp
 3278    972       19  20    0   260M   147M uwait    3  20:30   0.02% Plex Med
 1884 www           1  20    0    38M    10M kqread   2   0:02   0.01% nginx
ifconfig (ơn TrueNAS)
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
root@tim[~]# ifconfig
igb0: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=4a120b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWFILTER,RXCSUM_IPV6,NOMAP>
        ether ac:1f:6b:f3:14:e8
        inet6 fe80::ae1f:6bff:fef3:14e8%igb0 prefixlen 64 scopeid 0x1
        inet 192.168.0.110 netmask 0xfffffc00 broadcast 192.168.3.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
        nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
igb1: flags=8822<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=4e527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
        ether ac:1f:6b:f3:14:e9
        status: no carrier
        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
        groups: lo
pflog0: flags=0<> metric 0 mtu 33160
        groups: pflog
        ether 58:9c:fc:10:31:1a
        member: vnet10 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 10 priority 128 path cost 2000000
        member: vnet0.15 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 11 priority 128 path cost 2000
        member: vnet0.4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 9 priority 128 path cost 2000
        member: vnet0.3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 8 priority 128 path cost 2000
        member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 7 priority 128 path cost 2000
        member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 6 priority 128 path cost 2000
        member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 1 priority 128 path cost 20000
        groups: bridge
vnet0.1: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: LMS as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:11:51:ad
        hwaddr 02:67:69:f8:b7:0a
        groups: epair
        status: active
vnet0.2: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: Plex as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:31:41:ea
        hwaddr 02:cc:f3:a9:e5:0a
        groups: epair
        status: active
vnet0.3: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: URBackup as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:dd:cb:ac
        hwaddr 02:b2:7c:47:af:0a
        groups: epair
        status: active
vnet0.4: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: dokuwiki as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:b4:e5:2a
        hwaddr 02:df:3f:6f:10:0a
        groups: epair
        status: active
vnet0.15: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: syncthing as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:5b:07:f8
        hwaddr 02:b9:cf:9b:b1:0a
        groups: epair
        status: active
vnet10: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu1500
        options=80000<LINKSTATE>
        ether fe
So, Questions
Almost certainly user error!!!
What have I b*****ered up?
How do I fix it?
Do you need other stuff/info (Almost certainly!)
Tim1962
Just as an update... I configured as DHCP and this image results.
The default router is greyed out but is 172.16.0.1 but AFAIK I've never set it as this in TrueNAS nor pfSense. I tried stopping DHCP and set the router to 192.168.1.1 (pfSense) but when set back to DHCP the same router reappears???
Confused...
Patrick M. Hausen
Did you disable hardware offloading for the physical interface?
Tim1962
Thanks Patrick, got as far as thinking about it, but never went through with it.... (on TrueNAS GUI only I presume)
Patrick M. Hausen
You need to check that box labelled "Disable Hardware Offloading". Mandatory when running jails and VMs.
Tim1962
Hmm, I think I read the help box that said A will seriously damage performance, B only use if using jails, and only read the first sentence... However...
Ticked the box, took the warnings and when I restarted the jail got this
(I couldn't reset the "Disable Hardware Offloading" as each time I got a loop of "jail is still running" or the message below. Trying a reboot just now.)
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 73, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.9/socket.py", line 954, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno 8] Name does not resolve
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 358, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x82354fdc0>: Failed to establish a new connection: [Errno 8] Name does not resolve
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='www.freebsd.org', port=443): Max retries exceeded with url: /security/unsupported.html (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x82354fdc0>: Failed to establish a new connection: [Errno 8] Name does not resolve'))
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 139, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1246, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1151, in run_in_executor
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/jail_freebsd.py", line 827, in releases_choices
choices = {str(k): str(k) for k in ListableReleases(remote=remote)}
File "/usr/local/lib/python3.9/site-packages/iocage_lib/release.py", line 47, in __init__
self.eol_list = IOCFetch.__fetch_eol_check__()
File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_fetch.py", line 114, in __fetch_eol_check__
req = requests.get(_eol)
File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='www.freebsd.org', port=443): Max retries exceeded with url: /security/unsupported.html (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x82354fdc0>: Failed to establish a new connection: [Errno 8] Name does not resolve'))
homer27081990
Delete and re-create the bridge, run ifconfig (through SSH or console) in the jails and see if they get IPs.
Tim1962
Hi
Ran, ifconfig bridge0 down via console, (is that right way?) and then ifconfig via console gives this
        options=8120b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWFILTER>
        status: active
        status: no carrier
        groups: lo
        groups: pflog
        member: vnet0.11 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
        member: vnet0.10 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
        member: vnet0.9 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
        member: vnet0.8 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
        member: vnet0.7 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
        member: vnet0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 6 priority 128 path cost 2000000
        groups: bridge
vnet0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether fe:a0:98:38:bd:58
        hwaddr 58:9c:fc:10:f8:27
        groups: tap
        status: active
        Opened by PID 2103
vnet0.7: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        hwaddr 02:b8:41:b3:d6:0a
        groups: epair
        status: active
vnet0.8: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        hwaddr 02:33:ef:ef:75:0a
        groups: epair
        status: active
vnet0.9: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        hwaddr 02:d6:8e:b2:99:0a
        groups: epair
        status: active
vnet0.10: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        hwaddr 02:3d:33:fd:f6:0a
        groups: epair
        status: active
vnet0.11: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:
then ifconfig inside the "new" jail
To change this login announcement, see motd(5).
root@syncthing:~ # ifconfig
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
        groups: lo
        groups: pflog
epair0b: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:ff:6
can ping firewall etc from jail
Other jails seem to be running OK.
Syncthing, (the offending jail/pkg), seems to have stopped doing its thing (though not sure its directly related, it wasn't running for the last hour or two :smile: )
homer27081990
options=8<VLAN_MTU>
ether 02:ff:6
You get a partial mac address here (or didn't copy everything :wink:), if so, something is wrong with the virtual adapter of the jail.
Tim1962
Copy and paste error!!!
        groups: lo
        groups: pflog
        options=8<VLAN_MTU>
        ether 02:ff:60:5b:07:f9
        hwaddr 02:3d:33:fd:f6:0b
        inet 192.168.0.162  net mask 0xfffffc00 broadcast 192.168.3.255
groups:epair
media:Ethernet 10Gbase-T (10Gbase-T <full-duplex>)
status active
nd6 options=1 <PERFORMNUD>
does it matter that broadcast is 192.168.3.255 (which is the VPN Address/range?
homer27081990
Perfetto! Have a nice day! Just a last thought, carefully look the IPv6 setup of your router (if there is IPv6).
homer27081990
I don't mean to trouble you, but, if all is good, could you maybe edit the thread prefix as solved? That way it won't be visited by other people looking to help in the future. Thank you and have a nice day!
Tim1962
I'm not quite sure it was "Solved" but does seem to be resolved... !
I ended up deleting the jail, removing the bridge (ifconfig bridge0 down) rebooting, recreating the jail and installing synching into the jail. For some hidden/incomprehensible (for me) reason, synching is now chugging along quite happily
I can only thing something got corrupted with all my fiddling, and luckily fell back into place through no skill of my own :smile:
Cheers
homer27081990
Cheers
No, I think you did great. Its just that such systems that are made to run for years without a restart, even a login to see how things are going, don't usually take kindly to be tinkered with. Its just the nature of things. Have a nice day!
