Iocages are unable to connect to network but show up in bridge
Poetart
I just did a reboot of my Truenas instance to move drives to a new disk shelf.
After reboot, no errors but all of my jails have lost all connections to any networks. Truenas itself is working just fine.
The data for the iocages was not on the pool that was moved and no configuration or hardware adjustmets to the servers were made. Everything was already connected so just drives from one shelf to another.
Rebooted the server, replugged in the network connection, restarted the jails and nothing changes.
bge2 is the port that is plugged in.
ifconfig
bge0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c019b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,VLAN_HWTSO,LINKSTATE>
ether d4:ae:52:a6:31:77
media: Ethernet autoselect
bge1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether d4:ae:52:a6:31:78
bge2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether d4:ae:52:a6:31:75
inet 192.168.1.249 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
bge3: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether d4:ae:52:a6:31:76
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
ether 58:9c:fc:10:f6:3f
member: vnet0.8 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 14 priority 128 path cost 2000
member: vnet0.6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 17 priority 128 path cost 2000
member: vnet0.5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 16 priority 128 path cost 2000
member: vnet0.4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 15 priority 128 path cost 2000
member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000
member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
groups: bridge
vnet0.1: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: adguardhome as nic: epair0b
options=8<VLAN_MTU>
ether d6:ae:52:9c:5a:fe
hwaddr 02:4c:eb:ed:0b:0a
groups: epair
status: active
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 58:9c:fc:10:ff:97
member: vnet2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 13 priority 128 path cost 2000000
member: vnet1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 12 priority 128 path cost 2000000
member: vnet0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 11 priority 128 path cost 2000000
member: bge2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 3 priority 128 path cost 20000
groups: bridge
vnet0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=80000<LINKSTATE>
ether fe:a0:98:74:d7:f4
hwaddr 58:9c:fc:10:ff:91
groups: tap
status: active
Opened by PID 3782
vnet1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether fe:a0:98:ff:ff:ff
hwaddr 58:9c:fc:10:ff:e6
groups: tap
status: active
Opened by PID 3782
vnet2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether fe:a0:98:3a:3d:c1
hwaddr 58:9c:fc:00:6f:1e
groups: tap
status: active
Opened by PID 3815
vnet0.2: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: delugev5 as nic: epair0b
options=8<VLAN_MTU>
ether d6:ae:52:06:07:2c
hwaddr 02:60:74:ad:8f:0a
groups: epair
status: active
vnet0.4: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: radarrv3 as nic: epair0b
options=8<VLAN_MTU>
ether d6:ae:52:92:00:48
hwaddr 02:28:39:c7:bb:0a
groups: epair
status: active
vnet0.5: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: sonarrv4 as nic: epair0b
options=8<VLAN_MTU>
ether d6:ae:52:df:90:40
hwaddr 02:0b:e1:8b:76:0a
groups: epair
status: active
vnet0.6: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: unificontrollerv2 as nic: epair0b
options=8<VLAN_MTU>
ether d6:ae:52:e4:b9:51
hwaddr 02:7d:8f:bf:64:0a
groups: epair
status: active
vnet0.8: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: plexv2 as nic: epair0b
options=8<VLAN_MTU>
ether d6:ae:52:f2:7a:03
hwaddr 02:a5:61:dd:80:0a
groups: epair
status: active
Poetart
Self solve
Note if this happens to someone in the future:
Just rebuilt my linux VM with copied values and docker IP's. They both started at the same time and looks like they were causing all kinds of issues.
Preventing the old one from starting on boot prevented it and all the iocages started working after that.
