If you read my post carefully, you will see that I am aware of that.
Which is why I said something
like the Silverstone solution.
Essentially you can bifurcate pcie, externalize it via a set of cables and on the other side of the cable produce the equivalent pcie slot.
My Google fu isn't strong enough to find what that would look like exactly.
Though it seems to be that the cables are similar.
So theoretically you could bifurcate a x16 port into 4,4,4,4 though the cable itself seems to be limitation only allowing enough physical space for two physical cables so you can split an x16 port into 8,8 and then on the other side plug in whatever the hell you want.
Incidentally it seems as thunderbolt 3 solves this problem.
So I could just put a thunderbolt 3 card in and then connect to external enclosure which basically just caused me to rethink all of this.
Meaning I need to upgrade my existing storage, rather than a purchase of motherboard, case, and ram.
I could have purchased a thunderbolt 3 card, an 8bay thunderbolt 3 with an extra Pcie slot.
New users aren't able to edit their posts, because there's been a bunch of spammers who go back and edit their posts to add URL's, etc. You will gain the ability to edit posts at some point, I don't know what exact point, as I think it takes both account age and number of posts into account. Don't be shocked if a moderator takes several posts in rapid succession and merges them in an attempt to increase readability, in the meantime.
That explains it, once I get the ability to edit, I'll clean up the mess I have made of this thread.
If my motherboard supports thunderbolt 3 and I can find the right enclosure, I may send back all the stuff I purchased and migrate to this solution.
hell, I have a stack of old drives I can repurpose using this thunderbolt solution.
Well that was a hell of a rabbit hole. The answer is no thunderbolt isn't supported on my motherboard, and apparently thunderbolt support on motherboards is a unicorn feature. That kinds sucks.
