Simpleone71
- Mar 9, 2016
I have setup on my Freenas 11.1-u4 server a Ubunut 16.04LTS VM. I have it working, but have a weird problem with pinging the actual Freenas Server.
I have a static IP address setup and I can ping anything on my internal LAN and anything on my internal LAN can ping the Ubuntu machine. If I use SSH to the Ubuntu machine and ping my freenas box, it will resolve the name to the ip and then hang trying to ping. If I let it sit there long enough, it will sometimes just start pinging like normal. Even if I just try to ping directly the ip address of my freenas box, it will just sit there where it would normally tell you the bytes from etc, etc.
Sometimes on a reboot it will just instantly work and sometimes it takes forever to be able to ping the freenas box. I have gone over all my settings and do not see anything wrong. I'm fairly familiar with Ubuntu, but not Bhyve (am extremely familiar with VMWare ESXi) as this is my first attempt with using a virtual machine in freenas.
My biggest problem from this is that I'm trying to map a drive in this virtual machine on boot in fstab and since it sometimes can't get to the freenas box, it doesn't map.
Any suggestions?
Any suggestions?
