madtulip
- Mar 28, 2015
Today i changed my mainboard as the old one burned. The new MB didnt have an intel "igb0" ethernet adapter as before but a "re0" realtek bad thing.
The webGUi wouldnt show up and the console would hang in the screen shown here.:
https://doc.freenas.org/9.3/freenas_quick.html
Fig 3)a) right in the line after "14) Shutdown". I consider there is a bug in the script /etc/netcli (which i think is responsible for the console out depicted in Fig 3)a)). This script hangs if the previously configured NIC is no longer pysically present in the system so you can not use it to configure the new NIC.
I pressend ctrl+alt+f2 to get to a new responsive console window and logged in as root.
i edited /etc/rc.conf according to this page.:
https://www.freebsd.org/doc/handbook/config-network-setup.html
in order to setup a static IP for the re0 adapter by i.e. adding
i then restarted the netif service so that the rc.conf is parsed again and the adapter is initialized with the static ip
at this point i triied to ping my gateway - worked.
next problem was that the webinterface was still not responsive under the new ip, that /etc/rc.vonf would get overwritten after each reboot and that i didnt know how to access the configuration freenas uses for its NICs. I guess that information is stored in some database for the webinterface. i guess the webinterface triies to bind itself to the NIC during bootup, failed at that as the NIC did fail before and thus wouldnt start.
so we have to start the webservice manualy and hope that it binds to the new currently working "re0".:
iirc i started.:
which did restart the webinterface. For some lucky reason the webinterface now recognize the correctly configured "re0" and published itself on that although the wrong "igb0" entry was still present under network settings (in the webinterface).
in the webinterface i went to the network settings and deleted the "igb0" entry. afterwards the webinterface became unresponsive again and i rebooted the whole system. this point is also a little bit uncorrect/unintuitive/buggy i guess. It shouldnt bind to the NIC that is not configured in the webinterfaces settings. It was good luck for me that it did, because else i wouldnt know how to change the entry in the webinterfaces database.
Now that "igb0" was deleted the console out (/etc/netcli) wouldnt hang anymore after Fig 3)a) line "14) ...." (https://doc.freenas.org/9.3/freenas_quick.html).
I thus could execute option 1) of the console script to setup my "re0" adapter, which would correctly import those settings in the webguis database.
Im writing this so someone with the same problem might find this helpfull or it might get fixed.
have a nice day
ifconfig_re0="inet 192.168.1.3 netmask 255.255.255.0"
service netif restart
iirc i started.:
./usr/bin/sbin/nginx
have a nice day
