shadowcyberdeck
- May 2, 2021
Haven't seen any forums about my use case of a wildcard SSL (WCSSL) cert I have through my domain provider (NameCheap, not sure if this matters too much). To create the CSR I needed to give my provider before they could issue said WCSSL, I did the following in TrueNAS CORE v12.0-U8:
EDIT-1: Added Domain Provider, as I wasn't sure if that matters or not.
- Go to "System"
- Go to "Certificates"
- Click "Add"
- Change the following
- Type - CSR
- Under "Subject Alt. Names" I entered a couple other names for a few other services I plan on running (www, servicename1, servicename2)
- Wasn't sure how extensive if at all this needs to be
- Fill out all necessary info that has an "asterisk" next to it
- Leave everything else blank
- Click "Submit"
- Click "View" next to this new certificate
- Copy the "Signing Request" key and paste it into the CSR form on my domain provider
- Setup the CNAME as requested, while waiting for the certificate to get created
- Go to "System"
- Click "Add"
- Change the following:
- Type - "Import Certificate"
- Check "CSR exists on this system"
- Select my CSR under "Signing Certificate Authority"
- Paste CSR key from my domain provider
- Click "Submit"
- Go under "General"
- Select this new cert under "GUI SSL Certificate"
- Reload web console as requested
- Reload page one more time
- Get the stock browser error message that I can click through for invalid certificate, while still getting to my TrueNAS login page.
