Hi all, been trying to fix this without doing a restart. At the moment the apps are running in k3s as expected but the UI stopped working last night and the middleware daemon won't restart.
The only change made to the system outside of the apps would be installing nixstats which I use for monitoring (and ideally logging but I haven't gotten that working on TNS yet.)
NMAP shows that ports 80 and 443 are open (used by nginxproxy) and 8282 open (http UI) and 8443 closed (https UI). On both my browser and in-private window I get the same "Connecting to TrueNAS ... Make sure the TrueNAS system is powered on and connected to the network." message.
Thanks in advance! Let me know if any other info needed
my-name@truenas:~$ sudo service middlewared status × middlewared.service Loaded: not-found (Reason: Unit middlewared.service not found.) Active: failed (Result: signal) since Wed 2024-04-03 19:00:31 IST; 21h ago Duration: 1d 8h 33min 37.483s Main PID: 1821 (code=killed, signal=KILL) CPU: 2h 31min 6.857s Apr 03 04:02:49 truenas cron[1821]: 231128_1.1.2 Apr 03 04:02:49 truenas cron[1821]: 231128_2.0.4 Apr 03 04:02:49 truenas cron[1821]: Apr 03 04:02:49 truenas cron[1821]: Apr 03 04:02:49 truenas sudo[1184792]: pam_unix(sudo:session): session closed for user root Apr 03 19:00:19 truenas systemd[1]: Stopping middlewared.service - TrueNAS Middleware... Apr 03 19:00:31 truenas systemd[1]: middlewared.service: Main process exited, code=killed, status=9/KILL Apr 03 19:00:31 truenas systemd[1]: middlewared.service: Failed with result 'signal'. Apr 03 19:00:31 truenas systemd[1]: Stopped middlewared.service - TrueNAS Middleware. Apr 03 19:00:31 truenas systemd[1]: middlewared.service: Consumed 2h 31min 6.857s CPU time.
my-name@truenas:~$ sudo service middlewared start Failed to start middlewared.service: Unit middlewared.service not found.
