Web Gui Dies
skl111
So I have seen this happen before, and now it's happening again.
Fn 9.3
Fressh Install, and I am monitoring the 2 zpools from the web gui.
Doing 1 ZFS Send from pool a to b,
Web Gui dies, and I get the generic nginx error log message. If I restart django, it comes back up.
8GB Ram, Tri Core AMD, 14 Drives.
D
dlavigne
Guest
Post /var/log/messages for that point in time within code tags.
skl111
messages
Feb 13 08:42:41 freenas kernel: pid 15250 (python2.7), uid 0, was killed: out of swap space
nginx-error
2015/02/13 08:43:02 [error] 15177#0: *53 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.2.125, server: localhost, request: "GET /admin/alert/status/?1423834982868 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9042", host: "192.168.2.108", referrer: "http://192.168.2.108/"
2015/02/13 08:46:18 [error] 15177#0: *55 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.2.128, server: localhost, request: "GET /admin/alert/status/?1423835175320 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9042", host: "192.168.2.108", referrer: "http://192.168.2.108/"
2015/02/13 08:46:38 [error] 15177#0: *57 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.2.125, server: localhost, request: "GET /storage/home/ HTTP/1.1", upstream: "fastcgi://127.0.0.1:9042", host: "192.168.2.108", referrer: "http://192.168.2.108/"
2015/02/13 08:46:40 [error] 15177#0: *57 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.2.125, server: localhost, request: "GET /storage/home/ HTTP/1.1", upstream: "fastcgi://127.0.0.1:9042", host: "192.168.2.108", referrer: "http://192.168.2.108/"
2015/02/13 08:46:51 [error] 15177#0: *57 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.2.125, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://127.0.0.1:9042", host: "192.168.2.108"
2015/02/13 08:46:51 [error] 15177#0: *57 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.2.125, server: localhost, request: "GET /favicon.ico HTTP/1.1", upstream: "fastcgi://127.0.0.1:9042", host: "192.168.2.108"
df -h
Filesystem                                            Size    Used   Avail Capacity  Mounted on
freenas-boot/ROOT/default                             1.8G    934M    904M    51%    /
devfs                                                 1.0k    1.0k      0B   100%    /dev
tmpfs                                                  32M    5.3M     26M    17%    /etc
tmpfs                                                 4.0M    8.0k      4M     0%    /mnt
tmpfs                                                 2.7G     57M    2.6G     2%    /var
freenas-boot/grub                                     912M    7.8M    904M     1%    /boot/grub
z7                                                     10T    417k     10T     0%    /mnt/z7
z7/backups_z7                                          11T    713G     10T     6%    /mnt/z7/backups_z7
z7/media                                               10T     21G     10T     0%    /mnt/z7/media
z7/media/movies                                        12T    2.1T     10T    16%    /mnt/z7/media/movies
z7/media/tv                                            12T    1.7T     10T    13%    /mnt/z7/media/tv
z7/torrents_z7                                         10T    172G     10T     2%    /mnt/z7/torrents_z7
z3tb1                                                 1.7T     96k    1.7T     0%    /mnt/z3tb1
z3tb1/downloads                                       1.8T     94G    1.7T     5%    /mnt/z3tb1/downloads
z3tb1/dump                                            1.8T     65G    1.7T     4%    /mnt/z3tb1/dump
z3tb1/music                                           1.8T    111G    1.7T     6%    /mnt/z3tb1/music
z3tb1/videos                                          1.8T     72G    1.7T     4%    /mnt/z3tb1/videos
z7/.system                                             10T     84M     10T     0%    /var/db/system
z7/.system/cores                                       10T    1.5M     10T     0%    /var/db/system/cores
z7/.system/samba4                                      10T    752k     10T     0%    /var/db/system/samba4
z7/.system/syslog-ccfc0aed32f049219c9b42297c0761ef     10T    1.3M     10T     0%    /var/db/system/syslog-ccfc0aed32f049219c9b42297c0761ef
z7/.system/rrd-ccfc0aed32f049219c9b42297c0761ef        10T    236k     10T     0%    /var/db/system/rrd-ccfc0aed32f049219c9b42297c0761ef
I did not expect a reply so fast :) :)
D
dlavigne
Guest
Are you able to put more RAM in the system? 8GB may not be sufficient for the number of drives.
