we freenas happen trouble
xmbillion
hi,
please help me see image.
before we found freenas no use. check HBA card bad and system os disk same bad.
now we change new HBA card and new os disk.
but very read/write slow.
and maybe have error
2019年7月9日 19:47 - 卷 CLOUDDATA-112 状态为 ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
so this is disk bad?
xmbillion
pool: CLOUDDATA-112
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
   see: http://illumos.org/msg/ZFS-8000-9P
  scan: scrub repaired 0 in 1 days 09:01:36 with 0 errors on Tue Jun 18 00:01:39 2019
        CLOUDDATA-112                                   ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            gptid/720bdafe-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    10
            gptid/72e7f823-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    10
            gptid/74fcf83b-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    24
            gptid/76ebec83-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    14
          raidz1-1                                      ONLINE       0     0     0
            gptid/79549b06-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    16
            gptid/7a33f945-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    29
            gptid/7b111e0e-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    22
            gptid/7d3232fb-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    32
        cache
          gptid/b04cfbcf-a21d-11e9-81dd-ecf4bbc6db00    ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: none requested
        freenas-boot  ONLINE       0     0     0
          da0p2     ONLINE       0     0     0
melloa
I don't see error on your pool on the above picture.
Try run
smartctl -t long /dev/daX
for each disk and post results.
Could be a bad disk or you are out of space, so also post results for
zpool list
Hi @xmbillion. You'll want to run long smart tests with smartctl -t long /dev/<device> if you haven't already done so and after that provide the output of smartcl -a /dev/<device> for each of those drives. Specifically you're looking for lines like the following to show whether they are failing or experiencing issues.
5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
SweetAndLow
Sweet'NASty
your pool has a bunch of checksum errors and looks like you might have multiple disks failing. You didnt' setup smart tests or you would have gotten emails about this. Go setup emails and smart tests then run smartctl -t long /dev/daX for each disk. Post the output of smartctl -a /dev/daX for each drive also. You should back up your data and get ready to replace drives.
xmbillion
Try run
zpool list
[root@freenas ~]# smartctl -t long /dev/da1
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Extended Background Self Test has begun
Please wait 529 minutes for test to complete.
Estimated completion time: Thu Jul 11 08:17:27 2019
Use smartctl -X to abort test
NAME            SIZE  ALLOC   FREE  EXPANDSZ   FRAG    CAP  DEDUP  HEALTH  ALTROOT
CLOUDDATA-112  43.5T  7.61T  35.9T         -    56%    17%  1.00x  ONLINE  /mnt
freenas-boot    464G   757M   463G         -      -     0%  1.00x  ONLINE  -
xmbillion
oh. we have running
melloa
oh. we have running
529 minutes or ~9 hours.
Also get some drives burning in to be ready to replace the failing ones ... how many? OGK.
Go setup emails
Also don't forget this.
As there are many hands helping this, I'm stepping out. Good luck :cool:
xmbillion
you see we first image. i see all disk maybe have trouble. just issue hba card bad.
about email.
we freenas os is local network .
so set email have send out intelnet email?
Yes, check out the User Guide for your version.
You may also want to look at the user guide section on SMART tests.
oh. we have running
Start this for all of your drives, not just one. The tests can run in parallel, just keep using smartctl -t long /dev/{device}
xmbillion
Transport protocol:   SAS (SPL-3)
Local Time is:        Thu Jul 11 20:18:37 2019 HKT
SMART support is:     Available - device has SMART capability.
SMART support is:     Enabled
Temperature Warning:  Enabled
SMART Health Status: OK
Current Drive Temperature:     32 C
Drive Trip Temperature:        60 C
Manufactured in week 01 of year 2018
Specified cycle count over device lifetime:  10000
Accumulated start-stop cycles:  119
Specified load-unload count over device lifetime:  300000
Accumulated load-unload cycles:  499
Elements in grown defect list: 0
Vendor (Seagate) cache information
  Blocks sent to initiator = 1212365856
  Blocks received from initiator = 3182164856
  Blocks read from cache and sent to initiator = 16049530
  Number of read and write commands whose size <= segment size = 7612597
  Number of read and write commands whose size > segment size = 496608
Vendor (Seagate/Hitachi) factory information
  number of hours powered up = 9175.47
  number of minutes until next internal SMART test = 10
Error counter log:
           Errors Corrected by           Total   Correction     Gigabytes    Total
               ECC          rereads/    errors   algorithm      processed    uncorrected
           fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:   301396762        0         0  301396762          0        620.731           0
write:         0        0         0         0          0       3832.644           0
Non-medium error count:       32
[GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on']
Self-test execution status:             0% of test remaining
SMART Self-test log
Num  Test              Status                 segment  LifeTime  LBA_first_err [SK ASC ASQ]
     Description                              number   (hours)
# 1  Background long   Self test in progress ...   -     NOW                 - [-   -    -]
Long (extended) Self Test duration: 31744 seconds [529.1 minutes
Hi, please send the output of smartctl -a /dev/{device}. The above looks like just a summary. It is also helpful if you specify exactly what command you entered that gave you the output. :)
xmbillion
[root@freenas ~]# zpool status
  pool: CLOUDDATA-112
 state: ONLINE
            gptid/720bdafe-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    13
            gptid/72e7f823-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    11
            gptid/74fcf83b-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    25
            gptid/76ebec83-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    16
            gptid/79549b06-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    17
            gptid/7a33f945-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    35
            gptid/7b111e0e-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    24
            gptid/7d3232fb-8724-11e8-918a-ecf4bbc6db00  ONLINE       0     0    34
        cache
  pool: freenas-boot
 state: ONLINE
          da0p2     ONLINE       0     0     0
xmbillion
now we just running 1 disk other disk have no complete.
What are the values for
xmbillion
smartctl -a /dev/da2
Local Time is:        Fri Jul 12 15:11:17 2019 HKT
Current Drive Temperature:     33 C
Accumulated start-stop cycles:  116
Accumulated load-unload cycles:  475
  Blocks sent to initiator = 1544922848
  Blocks received from initiator = 1379678312
  Blocks read from cache and sent to initiator = 14254707
  Number of read and write commands whose size <= segment size = 10154820
  Number of read and write commands whose size > segment size = 592427
  number of hours powered up = 8717.82
  number of minutes until next internal SMART test = 44
Error counter log:
read:   386454913        0         0  386454913          0        791.000           0
write:         0        0         0         0          0       5115.914           0
Non-medium error count:       13
SMART Self-test log
Long (extended) Self Test duration: 32158 seconds [536.0 minutes
da3
Local Time is:        Fri Jul 12 15:12:13 2019 HKT
Current Drive Temperature:     34 C
Manufactured in week 28 of year 2017
Accumulated start-stop cycles:  148
Accumulated load-unload cycles:  614
  Blocks sent to initiator = 1325587112
  Blocks received from initiator = 1277942440
  Blocks read from cache and sent to initiator = 18499815
  Number of read and write commands whose size <= segment size = 11590944
  Number of read and write commands whose size > segment size = 517869
  number of hours powered up = 11358.55
Error counter log:
read:   345409179        0         0  345409179          0        678.701           0
write:         0        0         0         0          0       5056.825           0
Non-medium error count:       41
SMART Self-test log
Long (extended) Self Test duration: 33451 seconds [557.5 minutes]
da4
Local Time is:        Fri Jul 12 15:12:35 2019 HKT
Accumulated start-stop cycles:  139
Accumulated load-unload cycles:  626
  Blocks sent to initiator = 1284404944
  Blocks received from initiator = 971605112
  Blocks read from cache and sent to initiator = 13730224
  Number of read and write commands whose size <= segment size = 10945692
  Number of read and write commands whose size > segment size = 480231
  number of hours powered up = 11435.80
Error counter log:
read:   326889410        0         0  326889410          0        657.615           0
write:         0        0         0         0          0       4901.442           0
Non-medium error count:       18
SMART Self-test log
Long (extended) Self Test duration: 34230 seconds [570.5 minutes]
da5
Local Time is:        Fri Jul 12 15:12:56 2019 HKT
Accumulated load-unload cycles:  616
  Blocks sent to initiator = 1333510552
  Blocks received from initiator = 652819440
  Blocks read from cache and sent to initiator = 18808570
  Number of read and write commands whose size <= segment size = 11423975
  Number of read and write commands whose size > segment size = 453473
  number of hours powered up = 11672.70
  number of minutes until next internal SMART test = 57
Error counter log:
read:   345160529        0         0  345160529          0        682.757           0
write:         0        0         0         0          0       4736.355           0
Non-medium error count:       25
SMART Self-test log
Long (extended) Self Test duration: 34342 seconds [572.4 minutes]
xmbillion
da6
Local Time is:        Fri Jul 12 15:13:15 2019 HKT
Current Drive Temperature:     36 C
Manufactured in week 16 of year 2018
Accumulated start-stop cycles:  258
Accumulated load-unload cycles:  620
  Blocks sent to initiator = 1560232744
  Blocks received from initiator = 863937448
  Blocks read from cache and sent to initiator = 14910799
  Number of read and write commands whose size <= segment size = 9879633
  Number of read and write commands whose size > segment size = 536416
  number of hours powered up = 8776.88
  number of minutes until next internal SMART test = 9
Error counter log:
read:   387124578        0         0  387124578          0        798.839           0
write:         0        0         0         0          0       4850.732           0
SMART Self-test log
Long (extended) Self Test duration: 31236 seconds [520.6 minutes]
da7
Local Time is:        Fri Jul 12 15:13:35 2019 HKT
Current Drive Temperature:     35 C
  Blocks sent to initiator = 1633536984
  Blocks received from initiator = 1133474096
  Blocks read from cache and sent to initiator = 18971338
  Number of read and write commands whose size <= segment size = 10445208
  Number of read and write commands whose size > segment size = 574091
  number of hours powered up = 8717.92
  number of minutes until next internal SMART test = 59
Error counter log:
read:   450476459        0         0  450476459          0        836.371           0
write:         0        0         0         0          0       4985.113           0
Non-medium error count:       26
SMART Self-test log
Long (extended) Self Test duration: 33698 seconds [561.6 minutes]
da8
Local Time is:        Fri Jul 12 15:13:54 2019 HKT
Accumulated start-stop cycles:  143
Accumulated load-unload cycles:  610
  Blocks sent to initiator = 1301011736
  Blocks received from initiator = 451182336
  Blocks read from cache and sent to initiator = 14202836
  Number of read and write commands whose size <= segment size = 10687752
  Number of read and write commands whose size > segment size = 438716
  number of hours powered up = 11122.28
Error counter log:
read:   343821052        0         0  343821052          0        666.118           0
write:         0        0         0         0          0       4635.329           0
Non-medium error count:       20
SMART Self-test log
Long (extended) Self Test duration: 34097 seconds [568.3 minutes]
Fredda
It looks like the drive is a SAS drive and not a SATA one. SAS smart data looks that way. Although it looks the vendor information has been cut, so the first ~10 lines of the output are missing.
Ah yeah, thanks. I scanned too quickly.
These point to possible issues with cables or the controller. Check out this forum post or this smartmontools page. It looks like your drives don't have any `Total uncorrected errors`, this is a good thing. It looks like possibly all of your drives are reporting some Non-medium error count? If that does indeed indicate a communication issue it might be the controller rather than a cable.
Perhaps someone else has better ideas though.
