Hi!
I’m planning to set up a new pool and started researching what disks to get. I was somewhat surprised to find that the WD Red and WD Ultrastar DC are offered at almost the same price where I live (8 and 12 TB versions). Actually, the Ultrastars are slightly cheaper.
This got me wondering which ones to get. All are, to my best understanding, CMR drives. The Reds are 5400 rpm which I generally prefer, but the Ultrastars are marketed as higher reliability and have very good noice, heat and power consumption stats for 7200 RPMs. Also, the 12 TB Ultrastars are helium drives.
I plan to set up either 5x8 TB or 4x12 TB in Raid-Z2 for a total of 24 TB storage.
Based on your experience ...
1) would you go for Reds or Ultrastars and why?
2) if going for the Ultrastars, is it worth going for the 4x12 TB helium setup if it costs 20% more than the 5x8 TB non-helium setup? (i.e. I could get a 6x8 TB setup with 32 TB of usable storage for the same money)
Thank you in advance!
