I've shucked a couple of WD MyBook 10TB 5400rpm drives and wanted to use them with my SuperMicro X11SSL-CF.
I first plugged them into a SATA port and they were showing up fine.
Switched them to another system where I previously had a pool of eight WD Reds. I disconnected power to 4 of them and replaced the other four with the 10TBs to start a badblocks test.
But... nothing! No drives in the UI, none listed with smartctl --scan and camcontrol devlist. They are also not showing in the controller BIOS.
Any idea what might be the issue? Running 11.2U4.
Thanks!
Thanks!
