.warden-template-pluginjail directory delete
gabris
I uninstalled the all plugins and jails, but i don't know erase the.warden-template-pluginjail directory.
In the future I'd like to install Jails an other drive. How can delete the old dir?
D
dlavigne
Guest
That is most likely a dataset, if so it will show in View Volumes.
D
dlavigne
Guest
Does rm -Rf dirname delete it? If not, list the error.
gabris
No result.
see the list
Thanks
[root@freenas] /mnt/D2U300# rm -Rf jails
rm: jails/.warden-template-pluginjail/var/empty: Operation not permitted
rm: jails/.warden-template-pluginjail/var: Directory not empty
rm: jails/.warden-template-pluginjail/libexec/ld-elf32.so.1: Operation not permitted
rm: jails/.warden-template-pluginjail/libexec/ld-elf.so.1: Operation not permitted
rm: jails/.warden-template-pluginjail/libexec: Directory not empty
rm: jails/.warden-template-pluginjail/lib/libc.so.7: Operation not permitted
rm: jails/.warden-template-pluginjail/lib/libcrypt.so.5: Operation not permitted
rm: jails/.warden-template-pluginjail/lib/libthr.so.3: Operation not permitted
rm: jails/.warden-template-pluginjail/lib: Directory not empty
rm: jails/.warden-template-pluginjail/sbin/init: Operation not permitted
rm: jails/.warden-template-pluginjail/sbin: Directory not empty
rm: jails/.warden-template-pluginjail/usr/lib32/libcrypt.so.5: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/lib32/libthr.so.3: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/lib32/libc.so.7: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/lib32/librt.so.1: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/lib32: Directory not empty
rm: jails/.warden-template-pluginjail/usr/bin/chfn: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/opiepasswd: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/su: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/rlogin: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/chsh: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/chpass: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/ypchpass: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/login: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/crontab: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/yppasswd: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/opieinfo: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/passwd: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/ypchfn: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/rsh: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin/ypchsh: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/bin: Directory not empty
rm: jails/.warden-template-pluginjail/usr/lib/librt.so.1: Operation not permitted
rm: jails/.warden-template-pluginjail/usr/lib: Directory not empty
rm: jails/.warden-template-pluginjail/usr: Directory not empty
rm: jails/.warden-template-pluginjail/bin/rcp: Operation not permitted
rm: jails/.warden-template-pluginjail/bin: Directory not empty
rm: jails/.warden-template-pluginjail: Directory not empty
rm: jails: Directory not empty
D
dlavigne
Guest
On UFS, the system immutable flag is set in jails. Try running this command to remove that flag, then repeating the rm -Rf command:
chflags -R unschg dirname
gabris
No result, I formatted the complete disk. So the jails on the other UFS disk. It working.
Thanks.
burnt01
Thought I'd best comment as i had the same problem and finally got around to looking into it (i have just made a different jail location) this post helped me out!
chflags command got me on the right track, turns out its the related chattr before the rm command that fixed it for me:
http://en.wikipedia.org/wiki/Chattr
i used the -R flag (recurse all subdirectories) and -i (is to unset the immutable bit):
chattr -Ri path/to/directory
I used this command out side the jail,
I have found to do the same thing inside inside the jail (not to delete but to gain accees to rights) chflags does work but the command is :
chflags -R noschg path/to/directory
