I'm running TrueNAS-SCALE-22.12.0 on a personal home media server. Since the amount of users is going to be in the single digits, I do not plan on running it 24/7 to save on electricity bills, lessen the burden on the hardware etc and because I'm plain opposed to turning on a system that nobody is going to use.
Shutting down is easy, a simple on a cron job shuts the machine down at midnight.
Turning it on is harder. I figured I could turn WoL, since the motherboard supports it and the NIC supports it, but I've ran into issues there, I followed the guides I found but it is still not turning on. After finding a thread here about how trash Realtek drivers are, I've gone out of my way to purchase an Intel-based NIC to try using WoL with that, but no luck.
does not show that WoL with the magic packet is on despite ethtool saying that it is.
I'm out of ideas at this point. The guides that I followed were ASUS' for the BIOS (really just finding the APM settings and switching on power on by pci) and the WakeOnLan guide on the Debian wiki: https://wiki.debian.org/WakeOnLan#Enabling_WOL
After that it was just endless internet searches. A couple of them lead me here.
sudo poweroff
Hardware Information
- Motherboard: ASUS P8B75-V
- NIC: 10Gtek Intel I210-T1: https://www.amazon.de/dp/B01H6O7TMO?psc=1&ref=ppx_yo2ov_dt_b_product_details
- Onboard Motherboard NIC: Realtek 8111E/F (Currently not in use)
- CPU: i7-3770
What I've Done So Far
- Enabled WoL in the BIOS of the motherboard (Power On by PCI), I have confirmed that setting is still on
- Enabled WoL on the NIC in the Shell at first on the motherboard NIC using ethtool
- Enabled WoL on the PCI Intel NIC using ethtool
- Changed network configuration to enable WoL after a reboot and confirmed it stays on after a reboot (using files in
etc/network/interfaces.d
) - After failures, disabled the Realtek NIC using the TrueNAS SCALE UI so that all traffic runs through the Intel NIC
- Confirmed that the Intel NIC is the only one in use by disconnecting the LAN port of the motherboard and only using the Intel NIC
g
for both NICs. The only discrepancy I see is that Code:
ifconfig [NIC]
admin@truenas[~]# sudo ifconfig enp4s0 enp4s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.0.0.2 netmask 255.255.255.0 broadcast 10.0.0.255 inet6 fe80::9ab7:85ff:fe00:3f5 prefixlen 64 scopeid 0x20<link> ether 98:b7:85:00:03:f5 txqueuelen 1000 (Ethernet) RX packets 28211 bytes 24583721 (23.4 MiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 30019 bytes 27449120 (26.1 MiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device memory 0xf7200000-f72fffff admin@truenas[~]# sudo ethtool enp4s0 Settings for enp4s0: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supported pause frame use: Symmetric Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Auto-negotiation: on Port: Twisted Pair PHYAD: 1 Transceiver: internal MDI-X: off (auto) Supports Wake-on: pumbg Wake-on: g Current message level: 0x00000007 (7) drv probe link Link detected: yes
