Volume space question and volume config.
Rogla
Hi!
I think i have a volume with wrong configuration/setup and like to get some advice/confirmation.
It looks like I have two striped raidz2 vdevs. That was not the intention, one raidz2 vdev was the goal.
The simple reason is that I'm missing space.
There are 8 x 4 TB disk space, i expect nominal 6 x 4 = 24 TB compared to about 14 TB reported as (Used + Available) for the Dataset on the volume..
Checkpoint and replication is used, but only a few checkpoints are stored and no big changes between them so they should not cointain a lot of data.
Unless i'm failing to understand something....
The questions are:
1) Looking at the output below, is the volume really two striped raidz2 vdevs?
2) If, how do I rebuild the volume to have only one raidz2 vdev as easy as possible on 9.10-Stable?
Storage pic:
[root@sellafield ~]# zpool status
pool: volume1
NAME STATE READ WRITE CKSUM
volume1 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/52bd1d7f-4fc5-11e4-b903-b82a72d6f2c2 ONLINE 0 0 0
gptid/52f79936-4fc5-11e4-b903-b82a72d6f2c2 ONLINE 0 0 0
gptid/5332c03e-4fc5-11e4-b903-b82a72d6f2c2 ONLINE 0 0 0
gptid/536beb1f-4fc5-11e4-b903-b82a72d6f2c2 ONLINE 0 0 0
raidz2-1 ONLINE 0 0 0
gptid/53aa6575-4fc5-11e4-b903-b82a72d6f2c2 ONLINE 0 0 0
gptid/53e3d26d-4fc5-11e4-b903-b82a72d6f2c2 ONLINE 0 0 0
gptid/541f34b8-4fc5-11e4-b903-b82a72d6f2c2 ONLINE 0 0 0
gptid/545b8755-4fc5-11e4-b903-b82a72d6f2c2 ONLINE 0 0 0
errors: No known data errors
[root@sellafield ~]# zpool list -v
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
volume1 28.8T 12.4T 16.4T - 4% 43% 1.00x ONLINE /mnt
raidz2 14.4T 6.19T 8.19T - 4% 43%
gptid/52bd1d7f-4fc5-11e4-b903-b82a72d6f2c2 - - - - - -
gptid/52f79936-4fc5-11e4-b903-b82a72d6f2c2 - - - - - -
gptid/5332c03e-4fc5-11e4-b903-b82a72d6f2c2 - - - - - -
gptid/536beb1f-4fc5-11e4-b903-b82a72d6f2c2 - - - - - -
gptid/53aa6575-4fc5-11e4-b903-b82a72d6f2c2 - - - - - -
gptid/53e3d26d-4fc5-11e4-b903-b82a72d6f2c2 - - - - - -
gptid/541f34b8-4fc5-11e4-b903-b82a72d6f2c2 - - - - - -
gptid/545b8755-4fc5-11e4-b903-b82a72d6f2c2 - - - - - -
[root@sellafield ~]# zfs list -t all
NAME USED AVAIL REFER MOUNTPOINT
volume1 5.99T 7.50T 546K /mnt/volume1
volume1/.system 341M 7.50T 199M legacy
volume1/.system/configs-c7c03331e27944b6afc5cf519d212cdd 92.2M 7.50T 92.2M legacy
volume1/.system/cores 1.08M 7.50T 1.08M legacy
volume1/.system/rrd-c7c03331e27944b6afc5cf519d212cdd 34.2M 7.50T 34.2M legacy
volume1/.system/samba4 3.60M 7.50T 3.60M legacy
volume1/.system/syslog-c7c03331e27944b6afc5cf519d212cdd 10.8M 7.50T 10.8M legacy
volume1/archive 37.5G 7.50T 37.5G /mnt/volume1/archive
volume1/archive@auto-20181008.0700-1w 0 - 37.5G -
volume1/databackup 618G 7.50T 618G /mnt/volume1/databackup
volume1/databackup@auto-20181007.0800-1w 174K - 618G -
volume1/databackup@auto-20181008.0800-1w 0 - 618G -
volume1/dbbackup 2.33T 7.50T 2.33T /mnt/volume1/dbbackup
volume1/dbbackup@auto-20181007.1100-1w 1.18M - 2.30T -
volume1/jails 209K 7.50T 209K /mnt/volume1/jails
volume1/misc 273K 7.50T 273K /mnt/volume1/misc
volume1/misc@auto-20181007.1200-1w 0 - 273K -
volume1/osbackup 3.02T 7.50T 3.00T /mnt/volume1/osbackup
volume1/osbackup@auto-20181007.0900-1w 24.1G - 3.00T -
volume1/osbackup@auto-20181008.0900-1w 198K - 3.00T -
garm
You are right, you have a pool of two RAIDZ2 vdevs of four disks each. This gives you roughly 12 TB of net storage considering 20% CoW overhead.
To rebuild your pool to a single vdev of eight drives you simply destroy the pool and redo the “volume”.. this will destroy any data on the pool
A single raidz2 vdev of eight 4 TB drives will give you just shy of 19 TB of net storage. Please be aware that FreeNAS and ZFS don’t use the unit terabyte (TB) but tebibyte (TiB).
There is a resource on the forum with a ZFS calculator thanks to @Bidule0hm that is handy for this kind of questions.
That's correct.
Back up your data, destroy the pool, recreate it correctly, restore the data.
Rogla
Thanks for your answers!
So there is no easy way out.
I have to:
- stop the replication,
- destroy the pool on the PULL server and recreate it,
- restart replication and let it finish,
- stop the replication again,
- destroy the pool on the PUSH server and recreate it,
- copy back all data from the PULL server to the PUSH server,
- restart the replication again.
I hope 8 disks RAIDZ2 is a valid confuguration, I don't understand how it got striped from the beginning.
8 disk RAIDZ2 is a perfectly valid and sane configuration. It is quite commonly used. I've got three of them myself, in two servers.
Good luck with the storage reconfigurations. It is a PITA, but it makes sense to do it to increase the available storage.
