volume manager throws error.
no_connection
Latest update as of posting.
I used wizard to create my volume first time, but I noticed the storage tab looked different than usual.
You first have a volume then dataset ( even though zvol is the volume and not dataset)
However the mount points where odd (see PNG)
So I tied to recreate it with volume manager but got an exception (see pdf)
zvol seems to be created in the same way as wizard with mount points.
[root@AwesomeNAS ~]# zpool status
  pool: freenas-boot
state: ONLINE
  scan: none requested
        freenas-boot  ONLINE       0     0     0
          da6p2     ONLINE       0     0     0
errors: No known data errors
  pool: zvol
state: ONLINE
        zvol                                            ONLINE       0     0     0
          mirror-0                                      ONLINE       0     0     0
            gptid/5f8a87be-bc36-11e4-b6d2-9cb654954454  ONLINE       0     0     0
            gptid/6038dede-bc36-11e4-b6d2-9cb654954454  ONLINE       0     0     0
          mirror-1                                      ONLINE       0     0     0
            gptid/60e57ac7-bc36-11e4-b6d2-9cb654954454  ONLINE       0     0     0
            gptid/618e6beb-bc36-11e4-b6d2-9cb654954454  ONLINE       0     0     0
          mirror-2                                      ONLINE       0     0     0
            gptid/623f0265-bc36-11e4-b6d2-9cb654954454  ONLINE       0     0     0
            gptid/62ee75f9-bc36-11e4-b6d2-9cb654954454  ONLINE       0     0     0
  • FN_error.pdf
DrKK
FreeNAS Generalissimo
you named your pool "zvol"?
no_connection
When I made the same pool on same HW with FreeNAS-9.3-STABLE-201501241715 last time it worked fine.
So I might just go back and redo it without latest update.
I forgot to mention but update did fail and hang gui and shell. But I assumed they went fine as no new updates where available after a reboot (nice one after momentary press)
SweetAndLow
Sweet'NASty
The display under the storage tab is normal. And other than that I'm not sure what you are asking.
no_connection
Then they changed it from 9.2
Well no matter.
The mounts still seems wrong(mnt used twice) and I still get the exception when creating a new volume.
I will reinstall tomorrow and see if that helps.
yep =)
I have seen others use it as well.
Bad idea. Avoid common zfs and Unix terms. At best, they're confusing. At worst, they might be misinterpreted by some poorly-escaped script.
