my config:
- Supermicro X10SL7-F with 16GB ECC
- 6x 2TB Samsung F4 in a raidz2 environment
- no encryption
- freenas user since v8
my steps of the evil beginning:
- from 9.2.8 initiating a GUI upgrade with FreeNAS-9.3-RELEASE.GUI_Upgrade.txz and using the pool as temporary space for the installation (free space was min 300GB or more)
- after several reboots 9.3 is booting up, login in GUI successful - but no jails, syslog and sharing services are comming up
- storage tab says, there is no available space left in the datasets (AVAIL 0 at all datasets), very bad, cause the system dataset is also in this pool
strange behavior: there was a first level dataset with the same name of the pool. the pool was at 260GB free space or so, the dataset was at zero space and so all other child datasets
- there are warnings about the zfs version and the /dev/mps0 firmware in the GUI, so i do an 'zpool upgrade' and a firmware upgrade on my LSI 2308 to v16IT - maybe
- after reboot same symptoms, no space left in the datasets, so i do a fresh install from ISO with no config restore
- in the fresh system i used the wizard and tried to import the pool, same thing: no space left
- so i had to move the system dataset on another pool i created temporarily on a second usb stick, so after that i have the syslog and services again
- in the shell zpool import says:
- but it wont import again through the GUI with the following error:
- so i did a zpool status:
('dada' is the temporary pool for the system dataset)
- the storage section in the GUI doesn't show the pool or any dataset from the raidz2 either nor there is an option to import the pool again, so i used an zfs list to make sure that my pool and datasets aren't already gone:
Whats going wrong here and is there a chance to get my data available back again? I'm rather at a loss.
Thanks for trying to help me and sorry for my confuse spelling after 8 hours with this problem at this time of the day ( 3am ;) )
			my config:
- no encryption
[root@sleipnir] ~# zpool import
   pool: timmy
  state: ONLINE
action: The pool can be imported using its name or numeric identifier.
        timmy                                           ONLINE
          raidz2-0                                      ONLINE
            gptid/33c405da-aebd-11e2-9c37-00012e38c26a  ONLINE
            gptid/12022056-6ca6-11e4-9cb4-002590f3c778  ONLINE
            gptid/13bbe724-f1ab-11e0-9aee-00012e38c26a  ONLINE
            gptid/7c29f863-6bd2-11e4-9cb4-002590f3c778  ONLINE
            gptid/146b56bd-f1ab-11e0-9aee-00012e38c26a  ONLINE
            gptid/14cab269-f1ab-11e0-9aee-00012e38c26a  ONLINE
Dec 13 03:06:51 sleipnir manage.py: [middleware.notifier:3520] Importing timmy [15208926062868032888] failed with: cannot mount '/mnt/timmy/DATA': failed to create mountpoint cannot mount '/mnt/timmy/DATA/Applications': failed to create mountpoint cannot mount '/mnt/timmy/DATA/Ebooks': failed to create mountpoint cannot mount '/mnt/timmy/MEDIA': failed to create mountpoint cannot mount '/mnt/timmy/MEDIA/Filme': failed to create mountpoint cannot mount '/mnt/timmy/MEDIA/Musik': failed to create mountpoint cannot mount '/mnt/timmy/MEDIA/Serien': failed to create mountpoint cannot mount '/mnt/timmy/home': failed to create mountpoint cannot mount '/mnt/timmy/home/Julia': failed to create mountpoint cannot mount '/m Dec 13 03:06:51 sleipnir manage.py: nt/timmy/incoming': failed to create mountpoint cannot mount '/mnt/timmy/jails': failed to create mountpoint cannot mount '/mnt/timmy/jails/.warden-template-pluginjail-9.2-x64': failed to create mountpoint cannot mount '/mnt/timmy/jails/plexmediaserver_1': failed to create mountpoint cannot mount '/mnt/timmy/jails/pyload': failed to create mountpoint cannot mount '/mnt/timmy/jails/transmission_1': failed to create mountpoint Dec 13 03:06:51 sleipnir manage.py: [middleware.exceptions:38] [MiddlewareError: The volume "timmy" failed to import, for futher details check pool status]
[root@sleipnir] ~# zpool status -v
  pool: dada
state: ONLINE
  scan: none requested
        NAME                                          STATE     READ WRITE CKSUM
        dada                                          ONLINE       0     0     0
          gptid/2ee7b936-825d-11e4-9dc5-002590f3c778  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
        freenas-boot                                  ONLINE       0     0     0
          gptid/f650e296-8257-11e4-966f-002590f3c778  ONLINE       0     0     0
  pool: timmy
state: ONLINE
  scan: scrub repaired 928K in 18h31m with 0 errors on Sun Nov 30 18:31:17 2014
        timmy                                           ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/33c405da-aebd-11e2-9c37-00012e38c26a  ONLINE       0     0     0
            gptid/12022056-6ca6-11e4-9cb4-002590f3c778  ONLINE       0     0     0
            gptid/13bbe724-f1ab-11e0-9aee-00012e38c26a  ONLINE       0     0     0
            gptid/7c29f863-6bd2-11e4-9cb4-002590f3c778  ONLINE       0     0     0
            gptid/146b56bd-f1ab-11e0-9aee-00012e38c26a  ONLINE       0     0     0
            gptid/14cab269-f1ab-11e0-9aee-00012e38c26a  ONLINE       0     0     0
errors: No known data errors('dada' is the temporary pool for the system dataset)
[root@sleipnir] ~# zfs list NAME USED AVAIL REFER MOUNTPOINT dada 6.32M 1.66G 96K /mnt/dada dada/.system 4.98M 1.66G 2.35M legacy dada/.system/cores 96K 1.66G 96K legacy dada/.system/rrd-f36704f2fe794cb6a75657843255655d 2.15M 1.66G 2.15M legacy dada/.system/samba4 104K 1.66G 104K legacy dada/.system/syslog-f36704f2fe794cb6a75657843255655d 288K 1.66G 288K legacy freenas-boot 963M 6.27G 31K none freenas-boot/ROOT 954M 6.27G 31K none freenas-boot/ROOT/FreeNAS-9.3-STABLE-201412091831 954M 6.27G 931M / freenas-boot/ROOT/default 47K 6.27G 931M legacy freenas-boot/grub 7.81M 6.27G 7.77M legacy timmy 7.08T 0 13.5M /mnt/timmy timmy/.system 248M 0 320K legacy timmy/.system/cores 31.1M 0 31.1M legacy timmy/.system/rrd-c282aadcd9aa4260adb7b1137606b762 55.6M 0 55.6M legacy timmy/.system/samba4 6.19M 0 6.19M legacy timmy/.system/syslog-c282aadcd9aa4260adb7b1137606b762 155M 0 155M legacy timmy/DATA 470G 0 304K /mnt/timmy/DATA timmy/DATA/Applications 249G 0 249G /mnt/timmy/DATA/Applications timmy/DATA/Ebooks 19.6G 0 19.6G /mnt/timmy/DATA/Ebooks timmy/MEDIA 5.90T 0 304K /mnt/timmy/MEDIA timmy/MEDIA/Filme 2.92T 0 2.92T /mnt/timmy/MEDIA/Filme timmy/MEDIA/Musik 179G 0 179G /mnt/timmy/MEDIA/Musik timmy/MEDIA/Serien 2.42T 0 2.42T /mnt/timmy/MEDIA/Serien timmy/home 280G 0 256K /mnt/timmy/home timmy/home/Julia 85.4G 0 85.4G /mnt/timmy/home/Julia timmy/incoming 28.7G 0 28.7G /mnt/timmy/incoming timmy/jails 21.4G 0 791K /mnt/timmy/jails timmy/jails/.warden-template-pluginjail-9.2-x64 880M 0 874M /mnt/timmy/jails/.warden-template-pluginjail-9.2-x64 timmy/jails/plexmediaserver_1 17.2G 0 18.1G /mnt/timmy/jails/plexmediaserver_1 timmy/jails/pyload 3.11G 0 3.86G /mnt/timmy/jails/pyload timmy/jails/transmission_1 241M 0 1.08G /mnt/timmy/jails/transmission_1
