Volume Failed Import - need help
RamboRico
My motherboard crashed and need to move all my data to a new build. I have one volume broken up between two 500 disks. Every time it booted up in the new build it showed unable to read available disk space. So I detached the volume to try to reimport it automatically and now it keep getting an error stating, " The Volume failed to import, for further details check pool status". but when I check the zpool status only shows my 2nd volume and not volume I am trying to import.
Please help.
What's the output of zpool import POOLNAME?
RamboRico
	   software, or recreate the pool from backup.
   see: http://www.sun.com/msg/ZFS-8000-A5
		freenas-boot								  UNAVAIL  newer version
		  gptid/206b5b3b-ac7d-11e6-8bce-00146c7634e6  ONLINE
   pool: Volumen1
  state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
		devices and try again.
   see: http://www.sun.com/msg/ZFS-8000-6X
		Volumen1									  UNAVAIL  missing device
		  gptid/a444f4bf-73b9-11e2-9948-00137234dce3  ONLINE
		Additional devices are known to be part of this pool, though their
		exact configuration cannot be determined.
[root@LatineNAS ~]# zpool import Volumen1
cannot import 'Volumen1': one or more devices is currently unavailable
[root@LatineNAS ~]#
Single disk vdevs, huh? Guess what, that bad idea came back to bite you in the ass. Only one of the two is showing up.
Either get the other disk working or there is nothing anyone can do.
RamboRico
I didn't know that would be an issues or a bad idea. Thanks for the help.
How on earth can you say that?! Do you have a habit of using things that you know nothing about? It's not even a FreeNAS thing, it's a basic RAID concept.
I urge you to do some research before touching any servers, for your own safety.
SweetAndLow
Sweet'NASty
You're missing a disk that your pool needs. Fix that disk or your data is gone.
