aphmatt
- Sep 14, 2017
i'm running freenas 11.1 u5
here is what i want to setup:
VLAN70: ERX --> es-24-lite --> freenasVM1
VLAN80: ERX --> es-24-lite --> freenasVM2
VLAN90: ERX --> es-24-lite --> freenasVM3
etc...
I currently have VLAN70 scenario up and running and all is fine. I have the vlan setup on the erx and es-24 and life is good. VLAN70 VM (freenasVM1) is getting an address from the ERX. Can get to internet. thumbs up.
Now, I want to add VLAN80. 1st problem is I can't create the VLAN on es-24 using the same port as VLAN70 (which is where the erx is connected). Second, if this problem gets solved I can't see how to connect the VM to correct VLAN in freenas.
In freenas the only way i could see to let the VM know about the VLAN is to create the VLAN under networking and connecting it to igb1 but when I add the NIC device to the VM, the VLAN70 (in this case) isn't an option.
I'm very new to all this (as if you couldn't tell) and I'm probably attacking this from the wrong direction but any help/references would be much appreciated.
Thanks,
matt
**UPDATE** upgrading to 11.2-RELEASE-U1 fixed the issue as was suggested below.
etc...
- ERX will supply DHCP for each VLAN (VLAN70: 10.1.70.x, VLAN80: 10.1.80.x, etc)
- both will come through the igb1 port on freenas
Thanks,
matt
