VM problems
Charlie86
I want to run VM machine on my FreeNAS box
I have
Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
16GB of ram.
All I want from this VM is DNS server.
I use this tutorial watch
But when I try to power up VM I always get State: STOPPED.
Is problem in my old CPU or could be something else?
Charlie86
I am running FreeNAS-11.1-U6.3
Since EPT and UG features are shown, CPU is fine.
[root@freenas ~]# grep VT-x /var/run/dmesg.boot
VT-x: (disabled in BIOS) PAT,HLT,MTF,PAUSE,EPT,UG,VPID
About start on boot box, I am not sure where this is. If you mean "Autostart" check box in VM settings, then yes it is checked.
When I press start I even get green message on top of the screen "VM Started“
Is there any log files available?
D
dlavigne
Guest
Anything in /var/log/messages when it fails to start? Also, which OS is installed into the VM?
Charlie86
When I try to start VM in log file doesn't appear any new messages.
OS in VM is ubuntu-18.04.1.0-live-server-amd64.
Should this maybe be problem with permissions? I mention permissions because I am greenhorn in FreeNAS and have lots of problems with them :)
Mlovelace
VT-x: (disabled in BIOS) PAT,HLT,MTF,PAUSE,EPT,UG,VPID... I'll give you a hint ;)
Charlie86
When I see yours post, I was like 100% this is it.
I enable VT-x in BIOS
Now output shows
VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
But VM still Won't start. :(
also no log messages. I am lost.
Charlie86
UPDATE:
Just destroyed old VM and create new one.
Now VM starts, and I am able to connect to it via VNC, but still get some errors.
Screenshot below
Frederic996
Hi everyone, I apologize if I reopen an old thread but I have an equal problem, my vm does not start remains in boot efi.
I also tried to manually select in the boot file, but I'm not successful.
Installed version Freenas 11.3 U2
operating system to be installed on Windows 7
cmd--> grep output VT-x /var/run/dmesg.boot
"VT-x: PAT, HLT, MTF, PAUSE, EPT, UG, VPID"
Patrick M. Hausen
Windows 7 64 Bit? You cannot run 32 Bit on FreeNAS ...
Frederic996
[QUOTE = "Patrick M. Hausen, post: 580527, membro: 34727"]
Windows 7 64 bit? Non è possibile eseguire 32 bit su FreeNAS ...
[/ CITAZIONE]
Yes, I’m run windows7 64bit, but don’t work
