I've been playing around with VMs recently and having some issues in getting things going. My aim is to have one VM running Pi-Hole and another running a folding@home client. I was struggling to Ubuntu 18.04 Server as others have on this board have identified. Now 20.04 LTS is out I thought I'd give it a go.
Installing Ubuntu 20.04 went through easily and I was able to put Pi-Hole on and all seemed to work as expected.
Trying to install a second instance of Ubuntu 20.04 didn't work. I had planned to give it 3 cores and a couple of Gigs of memory on a Virt0 harddrive.
With 3 cores the installer failed when it attempted to scan the disk - VNC dropped out and wouldn't reconnect. Dropping the core count to 2 the installer progresses further but I get a brief IRQ error appearing on the install screen:
Several attempts left me low on memory so I decided to reboot the system (successfully initially - I could get to the Freenas web GUI which then crashes as) and this caused an IRQ storm slowing my home network to less than a crawl.
Any ideas on how to install Ubuntu for a second time and stop VMs causing IRQ storms? I have looked into IRQ storms previously but was not able to solve the issue beyond not running VMs.
I'm running a W3680 Xeon in a Supermicro X8STE, 16Gb EEC ram, a 10TB pool (5x2Tb drives).
Freenas 11.3-U2.1 running fairly vanilla - just some SMB shares and NextCloud all working as they should.
Many thanks
then if I look at the more detailed view all I see is a mass of errors and nothing progresses further.do_IRQ: 0.39 No irq handler for vector
Many thanks
