Hi everyone! A couple of days ago I migrate my TrueNAS CORE to TrueNAS SCALE. I had a VM with Ubuntu Server installed on it and it was working fine 'til I was on CORE but now when i try to start it throws me the following error: [EFAULT] VM will not start as NIC Device: re0 device(s) are not available.
The "More Info" option show me the following:
What am I supposed to do for not lose the content of this VM??
Thank you in advance
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 176, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1293, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1265, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1133, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 39, in start
await self.middleware.run_in_thread(self._start, vm['name'])
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1208, in run_in_thread
return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1205, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 62, in _start
self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name))
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 138, in start
raise CallError(
middlewared.service_exception.CallError: [EFAULT] VM will not start as NIC Device: re0 device(s) are not available.
