1. Trying to get Nextcloud set up based on this guide. From within my LAN, the jail IP takes me to It Works! and MYURL.COM takes me to Secure Connection Failed
2. I am getting the following syntax error.
3. Certbot fails with the message below. Port 443 and 80 are open and my URL resolves to my IP.
My Virtualhost file
root@nextcloud:~ # service apache24 restart
Performing sanity check on apache24 configuration:
AH00526: Syntax error on line 46 of /usr/local/etc/apache24/Includes/MYURL.COM.conf:
SSLCertificateFile takes one argument, SSL Server Certificate file ('/path/to/file' - PEM or DER encoded)3. Certbot fails with the message below. Port 443 and 80 are open and my URL resolves to my IP.
Saving debug log to /var/log/letsencrypt/letsencrypt.log Plugins selected: Authenticator webroot, Installer None Obtaining a new certificate Performing the following challenges: http-01 challenge for MYURL.com Using the webroot path /usr/local/www/apache24/data/nextcloud for all unmatched domains. Waiting for verification... Cleaning up challenges Failed authorization procedure. cloud.rangelmedianetwork.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://MYURL.com/.well-known/acme-challenge/9tOdxzuS2mMETnSD4J--rYXaZAx6zOXzX3y2jpflmVo: Error getting validation data IMPORTANT NOTES: - The following errors were reported by the server: Domain: MYURL.COM Type: connection Detail: Fetching https://MYURL.com/.well-known/acme-challenge/9tOdxzuS2mMETnSD4J--rYXaZAx6zOXzX3y2jpflmVo: Error getting validation data To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you're using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
My Virtualhost file
<VirtualHost *:80>
DocumentRoot "/usr/local/www/apache24/data/nextcloud"
ServerName MYURL.COM
RewriteEngine on
RewriteCond %{SERVER_NAME} =MYURL.COM
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
#ErrorLog ${APACHE_LOG_DIR}/error.log
#CustomLog ${APACHE_LOG_DIR}/access.log combined
<Directory /usr/local/www/apache24/data/nextcloud/>
Options +FollowSymlinks
AllowOverride All
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /usr/local/www/apache24/data/nextcloud
SetEnv HTTP_HOME /usr/local/www/apache24/data/nextcloud
Satisfy Any
</Directory>
</VirtualHost>
<VirtualHost *:443>
ServerAdmin Me@MYURL.COM
DirectoryIndex index.php
DocumentRoot /usr/local/www/apache24/data/nextcloud
SSLCertificateFile /usr/local/etc/letsencrypt/live/MYURL.COM/fullchain.pem
SSLCertificateKeyFile /usr/local/etc/letsencrypt/live/MYURL.COM/privkey.pem
SSLEngine on
# Intermediate configuration, tweak to your needs
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
SSLHonorCipherOrder on
SSLCompression off
SSLOptions +StrictRequire
<Directory /usr/local/www/apache24/data/nextcloud>
AllowOverride all
</Directory>
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
