SSL_ERROR_NO_CYPHER_OVERLAP when using EC certificates
Han Sooloo
I wanted to use EC certificates for the web interface. After creating the Root CA and a server cert based on that root, I restarted the web interface.
However, every browser that I use to connect complains about no overlapping ciphers being found.
If I use RSA certs, connections work.
Why can't FreeNAS' NGINX properly negotiate a TLS connection with EC certs?
Summary Findings:
  1. OpenSSL cipher list from FreeNAS command line definitely shows at least 2 ciphers that Firefox would have accepted: ECDHE-ECDSA-AES256-GCM-SHA384 and TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
  2. Even when I manually edit /usr/local/etc/nginx/nginx.conf and set ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:!RC4:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS; with a single cipher, NGINX _still_ cannot negotiate an overlapping cipher.
Additional Details:
When I run Wireshark on the client side, I see the following ciphers offered (standard Firefox TLS setup):
            Cipher Suites (18 suites)
                Cipher Suite: TLS_AES_128_GCM_SHA256 (0x1301)
                Cipher Suite: TLS_CHACHA20_POLY1305_SHA256 (0x1303)
                Cipher Suite: TLS_AES_256_GCM_SHA384 (0x1302)
                Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02b)
                Cipher Suite: TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (0xc02f)
                Cipher Suite: TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 (0xcca9)
                Cipher Suite: TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 (0xcca8)
                Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (0xc02c)
                Cipher Suite: TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (0xc030)
                Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (0xc00a)
                Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (0xc009)
                Cipher Suite: TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (0xc013)
                Cipher Suite: TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (0xc014)
                Cipher Suite: TLS_RSA_WITH_AES_128_GCM_SHA256 (0x009c)
                Cipher Suite: TLS_RSA_WITH_AES_256_GCM_SHA384 (0x009d)
                Cipher Suite: TLS_RSA_WITH_AES_128_CBC_SHA (0x002f)
                Cipher Suite: TLS_RSA_WITH_AES_256_CBC_SHA (0x0035)
                Cipher Suite: TLS_RSA_WITH_3DES_EDE_CBC_SHA (0x000a)
When I use OpenSSL on FreeNAS box to list the ciphers, I get the following:
root@zfs[/usr/local/etc/nginx]# openssl ciphers -v
ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AESGCM(256) Mac=AEAD
ECDHE-ECDSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH     Au=ECDSA Enc=AESGCM(256) Mac=AEAD
ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA384
ECDHE-ECDSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=ECDSA Enc=AES(256)  Mac=SHA384
ECDHE-RSA-AES256-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA1
ECDHE-ECDSA-AES256-SHA  SSLv3 Kx=ECDH     Au=ECDSA Enc=AES(256)  Mac=SHA1
SRP-DSS-AES-256-CBC-SHA SSLv3 Kx=SRP      Au=DSS  Enc=AES(256)  Mac=SHA1
SRP-RSA-AES-256-CBC-SHA SSLv3 Kx=SRP      Au=RSA  Enc=AES(256)  Mac=SHA1
SRP-AES-256-CBC-SHA     SSLv3 Kx=SRP      Au=SRP  Enc=AES(256)  Mac=SHA1
DH-DSS-AES256-GCM-SHA384 TLSv1.2 Kx=DH/DSS   Au=DH   Enc=AESGCM(256) Mac=AEAD
DHE-DSS-AES256-GCM-SHA384 TLSv1.2 Kx=DH       Au=DSS  Enc=AESGCM(256) Mac=AEAD
DH-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=DH/RSA   Au=DH   Enc=AESGCM(256) Mac=AEAD
DHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=DH       Au=RSA  Enc=AESGCM(256) Mac=AEAD
DHE-RSA-AES256-SHA256   TLSv1.2 Kx=DH       Au=RSA  Enc=AES(256)  Mac=SHA256
DHE-DSS-AES256-SHA256   TLSv1.2 Kx=DH       Au=DSS  Enc=AES(256)  Mac=SHA256
DH-RSA-AES256-SHA256    TLSv1.2 Kx=DH/RSA   Au=DH   Enc=AES(256)  Mac=SHA256
DH-DSS-AES256-SHA256    TLSv1.2 Kx=DH/DSS   Au=DH   Enc=AES(256)  Mac=SHA256
DHE-RSA-AES256-SHA      SSLv3 Kx=DH       Au=RSA  Enc=AES(256)  Mac=SHA1
DHE-DSS-AES256-SHA      SSLv3 Kx=DH       Au=DSS  Enc=AES(256)  Mac=SHA1
DH-RSA-AES256-SHA       SSLv3 Kx=DH/RSA   Au=DH   Enc=AES(256)  Mac=SHA1
DH-DSS-AES256-SHA       SSLv3 Kx=DH/DSS   Au=DH   Enc=AES(256)  Mac=SHA1
DHE-RSA-CAMELLIA256-SHA SSLv3 Kx=DH       Au=RSA  Enc=Camellia(256) Mac=SHA1
DHE-DSS-CAMELLIA256-SHA SSLv3 Kx=DH       Au=DSS  Enc=Camellia(256) Mac=SHA1
DH-RSA-CAMELLIA256-SHA  SSLv3 Kx=DH/RSA   Au=DH   Enc=Camellia(256) Mac=SHA1
DH-DSS-CAMELLIA256-SHA  SSLv3 Kx=DH/DSS   Au=DH   Enc=Camellia(256) Mac=SHA1
ECDH-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH/RSA Au=ECDH Enc=AESGCM(256) Mac=AEAD
ECDH-ECDSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AESGCM(256) Mac=AEAD
ECDH-RSA-AES256-SHA384  TLSv1.2 Kx=ECDH/RSA Au=ECDH Enc=AES(256)  Mac=SHA384
ECDH-ECDSA-AES256-SHA384 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AES(256)  Mac=SHA384
ECDH-RSA-AES256-SHA     SSLv3 Kx=ECDH/RSA Au=ECDH Enc=AES(256)  Mac=SHA1
ECDH-ECDSA-AES256-SHA   SSLv3 Kx=ECDH/ECDSA Au=ECDH Enc=AES(256)  Mac=SHA1
AES256-GCM-SHA384       TLSv1.2 Kx=RSA      Au=RSA  Enc=AESGCM(256) Mac=AEAD
AES256-SHA256           TLSv1.2 Kx=RSA      Au=RSA  Enc=AES(256)  Mac=SHA256
AES256-SHA              SSLv3 Kx=RSA      Au=RSA  Enc=AES(256)  Mac=SHA1
CAMELLIA256-SHA         SSLv3 Kx=RSA      Au=RSA  Enc=Camellia(256) Mac=SHA1
PSK-AES256-CBC-SHA      SSLv3 Kx=PSK      Au=PSK  Enc=AES(256)  Mac=SHA1
ECDHE-RSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AESGCM(128) Mac=AEAD
ECDHE-ECDSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH     Au=ECDSA Enc=AESGCM(128) Mac=AEAD
ECDHE-RSA-AES128-SHA256 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA256
ECDHE-ECDSA-AES128-SHA256 TLSv1.2 Kx=ECDH     Au=ECDSA Enc=AES(128)  Mac=SHA256
ECDHE-RSA-AES128-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA1
ECDHE-ECDSA-AES128-SHA  SSLv3 Kx=ECDH     Au=ECDSA Enc=AES(128)  Mac=SHA1
SRP-DSS-AES-128-CBC-SHA SSLv3 Kx=SRP      Au=DSS  Enc=AES(128)  Mac=SHA1
SRP-RSA-AES-128-CBC-SHA SSLv3 Kx=SRP      Au=RSA  Enc=AES(128)  Mac=SHA1
SRP-AES-128-CBC-SHA     SSLv3 Kx=SRP      Au=SRP  Enc=AES(128)  Mac=SHA1
DH-DSS-AES128-GCM-SHA256 TLSv1.2 Kx=DH/DSS   Au=DH   Enc=AESGCM(128) Mac=AEAD
DHE-DSS-AES128-GCM-SHA256 TLSv1.2 Kx=DH       Au=DSS  Enc=AESGCM(128) Mac=AEAD
DH-RSA-AES128-GCM-SHA256 TLSv1.2 Kx=DH/RSA   Au=DH   Enc=AESGCM(128) Mac=AEAD
DHE-RSA-AES128-GCM-SHA256 TLSv1.2 Kx=DH       Au=RSA  Enc=AESGCM(128) Mac=AEAD
DHE-RSA-AES128-SHA256   TLSv1.2 Kx=DH       Au=RSA  Enc=AES(128)  Mac=SHA256
DHE-DSS-AES128-SHA256   TLSv1.2 Kx=DH       Au=DSS  Enc=AES(128)  Mac=SHA256
DH-RSA-AES128-SHA256    TLSv1.2 Kx=DH/RSA   Au=DH   Enc=AES(128)  Mac=SHA256
DH-DSS-AES128-SHA256    TLSv1.2 Kx=DH/DSS   Au=DH   Enc=AES(128)  Mac=SHA256
DHE-RSA-AES128-SHA      SSLv3 Kx=DH       Au=RSA  Enc=AES(128)  Mac=SHA1
DHE-DSS-AES128-SHA      SSLv3 Kx=DH       Au=DSS  Enc=AES(128)  Mac=SHA1
DH-RSA-AES128-SHA       SSLv3 Kx=DH/RSA   Au=DH   Enc=AES(128)  Mac=SHA1
DH-DSS-AES128-SHA       SSLv3 Kx=DH/DSS   Au=DH   Enc=AES(128)  Mac=SHA1
DHE-RSA-SEED-SHA        SSLv3 Kx=DH       Au=RSA  Enc=SEED(128) Mac=SHA1
DHE-DSS-SEED-SHA        SSLv3 Kx=DH       Au=DSS  Enc=SEED(128) Mac=SHA1
DH-RSA-SEED-SHA         SSLv3 Kx=DH/RSA   Au=DH   Enc=SEED(128) Mac=SHA1
DH-DSS-SEED-SHA         SSLv3 Kx=DH/DSS   Au=DH   Enc=SEED(128) Mac=SHA1
DHE-RSA-CAMELLIA128-SHA SSLv3 Kx=DH       Au=RSA  Enc=Camellia(128) Mac=SHA1
DHE-DSS-CAMELLIA128-SHA SSLv3 Kx=DH       Au=DSS  Enc=Camellia(128) Mac=SHA1
DH-RSA-CAMELLIA128-SHA  SSLv3 Kx=DH/RSA   Au=DH   Enc=Camellia(128) Mac=SHA1
DH-DSS-CAMELLIA128-SHA  SSLv3 Kx=DH/DSS   Au=DH   Enc=Camellia(128) Mac=SHA1
ECDH-RSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH/RSA Au=ECDH Enc=AESGCM(128) Mac=AEAD
ECDH-ECDSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AESGCM(128) Mac=AEAD
ECDH-RSA-AES128-SHA256  TLSv1.2 Kx=ECDH/RSA Au=ECDH Enc=AES(128)  Mac=SHA256
ECDH-ECDSA-AES128-SHA256 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AES(128)  Mac=SHA256
ECDH-RSA-AES128-SHA     SSLv3 Kx=ECDH/RSA Au=ECDH Enc=AES(128)  Mac=SHA1
ECDH-ECDSA-AES128-SHA   SSLv3 Kx=ECDH/ECDSA Au=ECDH Enc=AES(128)  Mac=SHA1
AES128-GCM-SHA256       TLSv1.2 Kx=RSA      Au=RSA  Enc=AESGCM(128) Mac=AEAD
AES128-SHA256           TLSv1.2 Kx=RSA      Au=RSA  Enc=AES(128)  Mac=SHA256
AES128-SHA              SSLv3 Kx=RSA      Au=RSA  Enc=AES(128)  Mac=SHA1
SEED-SHA                SSLv3 Kx=RSA      Au=RSA  Enc=SEED(128) Mac=SHA1
CAMELLIA128-SHA         SSLv3 Kx=RSA      Au=RSA  Enc=Camellia(128) Mac=SHA1
IDEA-CBC-SHA            SSLv3 Kx=RSA      Au=RSA  Enc=IDEA(128) Mac=SHA1
PSK-AES128-CBC-SHA      SSLv3 Kx=PSK      Au=PSK  Enc=AES(128)  Mac=SHA1
ECDHE-RSA-RC4-SHA       SSLv3 Kx=ECDH     Au=RSA  Enc=RC4(128)  Mac=SHA1
ECDHE-ECDSA-RC4-SHA     SSLv3 Kx=ECDH     Au=ECDSA Enc=RC4(128)  Mac=SHA1
ECDH-RSA-RC4-SHA        SSLv3 Kx=ECDH/RSA Au=ECDH Enc=RC4(128)  Mac=SHA1
ECDH-ECDSA-RC4-SHA      SSLv3 Kx=ECDH/ECDSA Au=ECDH Enc=RC4(128)  Mac=SHA1
RC4-SHA                 SSLv3 Kx=RSA      Au=RSA  Enc=RC4(128)  Mac=SHA1
RC4-MD5                 SSLv3 Kx=RSA      Au=RSA  Enc=RC4(128)  Mac=MD5
PSK-RC4-SHA             SSLv3 Kx=PSK      Au=PSK  Enc=RC4(128)  Mac=SHA1
ECDHE-RSA-DES-CBC3-SHA  SSLv3 Kx=ECDH     Au=RSA  Enc=3DES(168) Mac=SHA1
ECDHE-ECDSA-DES-CBC3-SHA SSLv3 Kx=ECDH     Au=ECDSA Enc=3DES(168) Mac=SHA1
SRP-DSS-3DES-EDE-CBC-SHA SSLv3 Kx=SRP      Au=DSS  Enc=3DES(168) Mac=SHA1
SRP-RSA-3DES-EDE-CBC-SHA SSLv3 Kx=SRP      Au=RSA  Enc=3DES(168) Mac=SHA1
SRP-3DES-EDE-CBC-SHA    SSLv3 Kx=SRP      Au=SRP  Enc=3DES(168) Mac=SHA1
EDH-RSA-DES-CBC3-SHA    SSLv3 Kx=DH       Au=RSA  Enc=3DES(168) Mac=SHA1
EDH-DSS-DES-CBC3-SHA    SSLv3 Kx=DH       Au=DSS  Enc=3DES(168) Mac=SHA1
DH-RSA-DES-CBC3-SHA     SSLv3 Kx=DH/RSA   Au=DH   Enc=3DES(168) Mac=SHA1
DH-DSS-DES-CBC3-SHA     SSLv3 Kx=DH/DSS   Au=DH   Enc=3DES(168) Mac=SHA1
ECDH-RSA-DES-CBC3-SHA   SSLv3 Kx=ECDH/RSA Au=ECDH Enc=3DES(168) Mac=SHA1
ECDH-ECDSA-DES-CBC3-SHA SSLv3 Kx=ECDH/ECDSA Au=ECDH Enc=3DES(168) Mac=SHA1
DES-CBC3-SHA            SSLv3 Kx=RSA      Au=RSA  Enc=3DES(168) Mac=SHA1
PSK-3DES-EDE-CBC-SHA    SSLv3 Kx=PSK      Au=PSK  Enc=3DES(168) Mac=SHA1
