HOW-TO: Let's excrypt with Nextcloud/Owncloud
chris4795
Hello All,
I just got the Nextcloud plug-in properly configured with the Let's Encrypt SSL Certs, so I wanted to post my How-to. I based this off the following guides:
http://aairey.github.io/owncloud-letsencrypt
https://certbot.eff.org/#freebsd-apache
First, find the jail and execute from in there:
#jls
Nextcloud for me was 1, so to execute in it I used
#jexec 1 tcsh
Then, install the certbot:
#pkg install py27-certbot
Stop Apache, start the set-up wizard, and start apache again. I choose the stand alone mode:
#service apache24 stop
#certbot certonly
#service apache24 start
Next you will need to tell Apache which files to use. If you use Owncloud, go to:
#cd /usr/pbi/owncloud-amd64/etc/apache24/extra
For Nextcloud:
#cd /usr/pbi/nextcloud-amd64/etc/apache24/extra
I backup httpd-ssl.conf so if theres an issue, I can go back to it:
#cp httpd-ssl.conf httpd-ssl.conf.backup
Edit httpd-ssl.conf (find the lines that start with those variables and alter as needed). Also, change "your.domain.org" to the domain you own:
SSLProtocol all -SSLv2 -SSLv3
SSLCertificateFile "/usr/local/etc/letsencrypt/live/your.domain.org/cert.pem"
SSLCertificateKeyFile "/usr/local/etc/letsencrypt/live/your.domain.org/privkey.pem"
SSLCACertificateFile "/usr/local/etc/letsencrypt/live/your.domain.org/chain.pem"
SSLCipherSuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
SSLHonorCipherOrder on
SSLCompression off
Restart apache
#service apache24 onerestart
I got the following error, I believe you can safely ignore it:
Error output from None:
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message
Syntax OK
Next, do a dry-run of the update:
#certbot renew --pre-hook "service apache24 stop" --post-hook "service apache24 start" --dry-run
I got that same error as above, but it ran happily.
Let's encrypt recommends running it twice a day (if it doesn't need to renew it will not shut down apache), so I added this to my crontab:
#crontab -e
45 11,23 * * * certbot renew --pre-hook "service apache24 stop" --post-hook "service apache24 start" --quiet
I believe (I'm not an expert on cron, so please forgive me if this is wrong) that the scriptt will run at 11:45 am and 11:45 PM every day to check for renewing.
Check it is there with:
#crontab -l
As of now, I do not have HSTS working on this configuration. If you know how to I would appreciate knowing how to.
passmossis
You're guide works well, just so happened to be setting up the very same thing today and was working on tracking down the appropriate file locations.
On your cron I went with a twice a month instead of a twice a day approach. The certs are good for three months so will check for an update on the 1st and 15th of each month.
45 23 1,15 * * certbot renew --pre-hook "service apache24 stop" --post-hook "service apache24 start" --quiet
Or do you update frequently to catch of DDNS updates?
chris4795
The certbot website (i.e. the people behind Let's Encrypt) recommends twice a day, that's why I went with that. FreeNAS already has a plane in services to automatically update DDNS, so I am not worried about that.
FreeN@s!
thanks, it worked perfectly.
kriegalex
Thank you very much, this helped me save a lot of time compared to my old "self-taught how to get HTTPS" for my previous owncloud jail
xTitus Maximusx
for HSTS add this
<IfModule mod_headers.c>
	  Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
	</IfModule>
to the
/usr/pbi/nextcloud-amd64/etc/apache24/Includes/nextcloud.conf
dureal99d
Perhaps im just stupid, cause non of these tutorials work for me, i ran the command to a T but im getting no where at "httpd-ssl.conf" i edit the file but mine has non of what yours has in it.
im just confused? i just want to be able to access my client internally and externally using a secuure method. i guess im just lost on this cause i just dont get it.
q_fleuren
Did you end up with a working setup? if not pm me and ill help you out
jorgenGSL
i am verry new with this and I am stuck in the wizard.
you need to fill in a domain name . so i made a free domain name and linked it throug my glabal ip and port number for https (??)
but when i fill this in in the wizard is does not work:
fault:
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.
pls help
I do not know much about this
dureal99d
you need to fill in a domain name . so i made a free domain name and linked it throug my glabal IP and port number for https (??)
fault:
pls help
make sure port 80 and 443 are open on your router.
fault:
There's more to the error message than this--what are the next few lines above this?
This is a misleading error from certbot, as it's what's given any time validation fails. And yes, DNS issues are one possible reason, but so is firewall configuration (as @dureal99d mentions), incorrect webroot path, misconfigured webserver, etc. The text that's given above what you quoted will show what happened when they tried to validate.
Zxarr
Just got my FreeNAS 11.2 system installed and starting to set up services while data transfers. I currently use Owncloud in an ESX VM, but installed NextCloud successfully on FreeNAS, no real issues until I came to get a SSL certificate, where I found this thread... However, this is what happens:
root@nextcloud:/ # pkg install py27-certbot
Updating iocage-plugins repository catalogue...
iocage-plugins repository is up to date.
All repositories are up to date.
pkg: No packages available to install matching 'py27-certbot' have been found in the repositories
Any ideas?
